I know the forum rules are to read first ask after you can't find...but i am out in the middle of no where and my internet connection thru the satelite went south tuesday morning so what we currently have is like 24k thru a phone line. Waiting on my tools to hit the table here shortly so i can go home to civilization for awhile while they move this oil rig to a new pad. So since i am doing the front brakes on the chalet with ebc pads and cross drilled rotors i'd like to bust out my tsm rear disc brackets i've had stashed for the last 3 or 4 years and just get it done. I need part numbers for a disc/disc master and prop valve. 76 K5 with 87 master and booster currently. I'll be going to a local book store when i get home to log on to see if anybody has the numbers from gm...azone...who ever...where ever so i can order them and get them here on the next day pony. If you want call me at 970-250-3800 and leave me a message if you want...just need to get the darn thing fixed before the next job as driving my wifes old 89 honda civic si in the oil field just doesn't cut it....i'll be lucky to pile all my gear in it all at once to get home! Thamnx guys!
DW
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
Re: Need a part number or two...
what year veh are you wanting the master and prop valve off of?
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
PN is MC390545P from http://www.mpbrakes.com
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
I was hoping to find something i could aquire through a local parts house so i don't have pay a premium for someones super secret application. I have heard a 81 vette master will work but i ran out of time once again. All i managed to do was convert the front calipers to a JB7 option with cross drilled rotors and EBC pads. Seems to stop alot better! But that was a quick test run. Headin back to work here in a bit....will get back to the hunt once i have some free time tomorrow....
Thanx for all the help and a special thanx to cpt caos for the phone call. I really appreciate you going out of your way to make a call...things like that is why i spend more time here than CK5 anymore... DW
Oh,you can't buy that new
![]() Join Date: Apr 2000
DOug, on CK5 your thread is buried 5 minutes later, thats why. I have some factory part numbers but only up to 85, DAVID
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
Crossy...that should work fine. I'm not sure what year gm increased the master cylinder bore from 7/8's to 1 1/1/8th....
A friend mentioned he thought a 81 vette master would work. And he told me that the current master could be used if the rear brake port ball and spring was removed...esentially a residual valve for the drum brakes. He said to get rid of the prop valve all together and tee the front lines together and make a bracket to mount a wilwood valve on the master for the rear lines. DW
my 85 book is for light trucks only, is there anything in there you need ? ,DAVE
Ahh...the factory bibles. I have those too...there are just currently in storage. The latest one i have is 90...for the R/V series. I was assuming you had some gm numbers you used to do rear disc like master cylinder....
DW
REAR DISCS< LOL i haven't even got to put the factory front discs on the Chevelle yet.
OEM part # for 82 vette master cylinder is 18014644. $232.12 list price
OEM part # for 82 vette prop/combintaion valve is 1257208. $111.02 list price. hope this helps.
