07-01-2006, 05:15 PM | #1 |
Insert Title Here
These tubular arms for stock shaft
what do you guys think of these? the drivers side is supposed to built to clear the stock shaft.. or would a multi link be just as good
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
07-01-2006, 05:15 PM | #2 |
Insert Title Here
Re: These tubular arms for stock shaft
oh and its for when aired out and laying frame
07-01-2006, 06:06 PM | #3 |
Man thats trick. Who built those control arms? I am planning on baggin a 67 step side and am trying to get a good knowledge base of everything. is you dont mind how much did they cost? Thanks and looks good!!
07-01-2006, 06:35 PM | #4 |
Insert Title Here
These guys.. and they dont have a price on them.. i havent looked that far into them yet
http://www.settintrendz.com/
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 07-01-2006 at 06:35 PM. |
07-03-2006, 09:00 AM | #5 |
those are for a 73-87 trucks but would look killer on the 67-72s but they should clear because u can see were the notch is in the arms for the steerin arm
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
07-03-2006, 11:59 PM | #6 | |
its just $$$$$
07-08-2006, 04:07 PM | #7 |
1LoC10, where did you find those pics? I've looked all over their site and found nothing on those arms. It looks like they z'd the frame or did a stock floor body drop, but either of those should move the steering box up in relation to the cab, which would not leave a straight shot from the bottom of the column to the steering box. Any more info on what they did to that truck?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
07-10-2006, 01:52 PM | #8 |
Those look good but I noticed one thing. Did they use DOM tubing for the arms?
Later Jr
Please become a site supporting vendor to advertise a business in your signature. you can do so here |
07-10-2006, 09:02 PM | #9 | |
Even if it wasn't, it should still be stronger vs. the stamped factory arms right? What do you guys think?
07-10-2006, 09:40 PM | #10 | |
07-11-2006, 12:44 AM | #11 | |
07-10-2006, 11:45 PM | #12 | |
Jr do you see an electricweld seam that I don't? You would think they're DOM or maybe even solid by the way the one side bent (no deformity). Looks like a good idea. |
07-11-2006, 12:49 AM | #13 | |
07-10-2006, 03:16 PM | #14 |
whats the largest size wheel you can run with these? if they will allow a 22 to lay frame ill buy a set.
07-10-2006, 09:31 PM | #15 |
Insert Title Here
im not sure... this is the forum where I seen them... I don't know anyhting about these guys, but I was interested in them
http://www.streetsourcemag.com/forum...M=False&S=True
