07-04-2006, 02:38 PM | #1 |
Glove box liner question.
I received my new glove box liner last week. After sitting down in the truck with it, and looking real good, it looks as if I will have to remove everythig from under the dash to install it? Is there a way that this thing can be colapsed w/out messing it up too bad? Or am I just going to have to remove and reinstall everything under the Passenger side? I hope someone here has a magical trick of some kind?
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
07-04-2006, 02:47 PM | #2 |
Rottenwood Garage Member
Re: Glove box liner question.
If you take the gloovebox door off (have to anyway) you should be able to work it in. They are tough...but I have gotten both AC cab and non AC cabs in from the front.
I dont think there is a truck.....just a lot of time |
07-04-2006, 03:32 PM | #3 |
I second that, just take your time and be carefull.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
07-04-2006, 03:34 PM | #4 |
i cut the top left corner so i could get it in. it's an AC truck
07-04-2006, 03:35 PM | #5 |
I just installed mine last week. Non-ac box. Went through the front after removing the door. No need to remove anything under the dash.....
1997 GMC Sierra Ext 1965 Mustang |
07-04-2006, 05:30 PM | #6 |
Ok, Thanks. I wasn't in a patient mood when I looked at it, so I didn't look at it very hard. Asking here came to mind first. Thanks for the info. I'll give it a shot. Mine is/was an A/C truck, half of which is missing. But that is a whole new set of problems, to be addressed at a later time.
Jay
07-04-2006, 05:39 PM | #7 |
20' Daredevil (Ret)
I have replaced mine twice (A/C truck) by removing the glove box door and going through the front. It is a PITA and you will bend the cardboard a bit, but it can be done.
Then again, I used to drink beer during all my projects.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
07-04-2006, 09:37 PM | #8 |
18 Till I Die
I will be selling aluminum ones in the fall if your interested.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
