Old 07-06-2006, 01:14 PM   #1
RunTMCfan
RunTMCfan's Avatar
Another TPI question
I'm gonna buy a crate motor in the coming months. I plan on racking my brain and installing a TPI from an older chevy.
What are the ideal cars (if any)to pick from for this application.
Do I need to purchase a certain crate motor to properly bolt on the system?
Should I have the old Fuel Injection ran through by somebody to make sure it's as good as new?
Rob
"RunTMCfan"
RunTMCfan is offline   Reply With Quote
Old 07-06-2006, 02:06 PM   #2
Josh
He's got mean nasty FANGS!
Josh's Avatar
Re: Another TPI question
Moving to Engine and Drivetrain for better visibility.
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 07-07-2006, 06:49 AM   #3
MikeS
Active Member
MikeS's Avatar
The TPI swap is pretty straightforward but do your research first. There were some important differences between the different versions of TPI that GM put on Camaros, Firebirds, and Vettes, even within the same year. There are a bunch of great websites and a couple of books around that helped me a lot.
www.chevythunder.com
www.jagsthatrun.com
www.thirdgen.org
The best thing to do is to find a complete, running Z28 or TransAm. That way you can be sure that the TPI is working well and you'll have all the sensors, etc. needed to make it work. Try and get one with a 350, not a 305 like I did since the injectors and sensors are different.
If you are getting a crate motor, get one with the newer style center bolt heads, it'll make the intake install easier since there are 2 different versions of the intake which differ in the angle of the 2 middle bolt holes on each side.
The most time consuming part for me was the plumbing. You need to put in an electric fuel pump and a new fuel lines. The stock supply line is too small and you need a return line. I also installed an intank pump with a built in baffle for more reliability. You'll also have to have a bung for the O2 sensor welded into your exhaust manifold. If you've got headers like I do, it goes after the collector and you need to use a heated O2 sensor which means a little extra wiring.
It's a fun upgrade to do but it isn't exactly a bolt on. I've kept the entire parts list from my install which might help.
Keep asking questions.
The rides:
'72 Blazer 350/4spd/Tuned Port Injection
'69 Firebird 400/4 speed
2001 Dodge Dakota Sport 4X4/4.7L V8/5 spd/Headers/Jet Chip, etc. Daily Driver
2002 Airborne Zeppelin (roadbike) Titanium frame/Campy Chorus
2004 Filippi Italia S (rowing shell)
MikeS is offline   Reply With Quote
Old 07-08-2006, 03:32 AM   #4
53burb
53burb's Avatar
www.jagsthatrun.com
www.thirdgen.org
MikeS,
I would be interested in your parts list. I have a TPI from an '86 on the way.
53burb is offline   Reply With Quote
Old 07-13-2006, 07:53 PM   #5
MikeS
Active Member
MikeS's Avatar
Originally Posted by 53burb
MikeS,
PM'ed you. It's in an Excel file.
The rides:
Old 07-07-2006, 10:45 AM   #6
Jason915
I did a TBI on my Blazer and it was even easier than a TPI set up. I am very happy with it. A TBI would give you the same bennifits and results as a TPI but would cost less and be slighlty easier. If you want some info on it let me know and I'll do a write up on it.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 07-07-2006, 12:57 PM   #7
RunTMCfan
RunTMCfan's Avatar
Did someone say a write up??? Can't read enough of them.
I was gonna ask the 305 vs. 350 question but didn't think it mattered. I read previousely that a full car is the way to go. I will definately do that and make sure it has a 350.
Thanks guys.
As always more input is appreciated.
Rob
"RunTMCfan"
Old 07-07-2006, 01:06 PM   #8
RunTMCfan
RunTMCfan's Avatar
Does the fuel injection need to be tuned up??? It is old...
Rob
"RunTMCfan"
Old 07-07-2006, 01:25 PM   #9
Jason915
I'll work on a TBI conversion write up.
Old 07-07-2006, 04:05 PM   #10
Jason915
http://67-72chevytrucks.com/vboard/s...44#post1750844
Old 07-31-2006, 10:52 PM   #11
obsesive23
Who me?
obsesive23's Avatar
Ok dumb question, how do you tell the difference between a 305 and a 350?
I found a 86 Iroc today that runs and drives for $500 and I'am not sure it is a 350 or not.
Living the dream
72 2WD Blazer, under going porter built surgery
67 GT Mustang fastback
67 Mustang coupe C/S clone
64 Falcon sprint hardtop
obsesive23 is offline   Reply With Quote
Old 07-31-2006, 11:11 PM   #12
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
86 did not have a 350 but there is a remote chance that it had a 350 swap.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 07-31-2006, 11:20 PM   #13
obsesive23
Who me?
obsesive23's Avatar
What years should I look for? Does the corvettes differ?
Thanks for the heads up.
Living the dream
Old 07-31-2006, 11:30 PM   #14
MylilBowTie
Right turn Clyde
87/88-92 Camaro and I'm not sure on the Vettes but they also had 350 TPI engines. Id say about 86ish to 90-91 I'm pretty sure 92 was LT1 engines. Maybe someone else will be better on the years for the Corvette.
Depending on what you want to do you can use a tbi 350. Its pretty much the same short block as a tpi engine. They are tapped for roller camshafts but don't have the tpi heads or roller cam usually but all that can be installed.
