Old 07-11-2006, 09:40 AM   #1
Green Monster
Green Monster's Avatar
Difficult to turn key in ignition lock cylinder. Key question too.
My ignition lock cylinder is worn. I have to push the key down to get it to turn the key once insterted. Took me months to figure this out. I used to do the wiggle wiggle wiggle everytime till it turned.
Does anyone else have this problem?
I have new keys that were given to me by the previous owner. While the keys appear to have nicer cuts on them, they do not work as well as my old worn key.
So, here is my question. If I replace the ignition lock cylinder, do I have to change out the door locks too if I want to use the same key for both the ignition and doors? Or do the doors and igition use different parts of the key?
Green Monster is offline   Reply With Quote
Old 07-11-2006, 12:23 PM   #2
MikeS
Active Member
MikeS's Avatar
Re: Difficult to turn key in ignition lock cylinder. Key question too.
Easiest thing to do is just change the ignition cylinder. If you want to you can get the complete set of ignition and 2 door cylinders. Or, if your door locks work fine (actually no point in locking the doors if you've got the top off!) just do the ignition and then you'll have two keys.
The rides:
'72 Blazer 350/4spd/Tuned Port Injection
'69 Firebird 400/4 speed
2001 Dodge Dakota Sport 4X4/4.7L V8/5 spd/Headers/Jet Chip, etc. Daily Driver
2002 Airborne Zeppelin (roadbike) Titanium frame/Campy Chorus
2004 Filippi Italia S (rowing shell)
MikeS is offline   Reply With Quote
Old 07-11-2006, 12:32 PM   #3
tom71
what happened to flint mi
tom71's Avatar
any reputable locksmith can rekey the doors to your new ignition key , its cheaper if you pull the locks out of the blazer and bring them to the locksmith
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 07-11-2006, 01:59 PM   #4
Pop's72
It's ok to stare...
Pop's72's Avatar
When I bought my Blazer I didn't want any keys floating around for my truck, so I bought new key set from Early Classic that consisted of a 2 door keys, 1 ignition key, and 1 glovebox key for about $50. I believe that Brothers now has the similar key kit available, but I am not sure on the price. My back hatch lock and key is still the same as it didn't match my previous keys and dealing with it is a pain in the...
Just be careful that when you remove the door locks you don't take any paint with you.
Pop's72 is offline   Reply With Quote
Old 07-11-2006, 07:29 PM   #5
Green Monster
I know the top is off, but I really like having the truck the way it was from the factory, one key does it all. Now, if any reputable locksmith can rekey the doors, will he be able to rekey my hatch too? If not, is there any kits with a hatch lock included?
Old 07-12-2006, 09:50 AM   #6
69TowRig
No kits with hatch locks that I know of. I bought a 3-piece lock kit (both doors and ignition) for $25 from GMC Pauls. The 4-piece with glovebox lock is $40. The closest to OEM look aftermarket hatch handle I can find you can buy at Northern Tool & Equip, but the keys are a completely different style.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 07-12-2006, 09:53 AM   #7
cdowns
cdowns's Avatar
ever think about spraying some lubricant in the lock cylinders to make them work easier??
Old 07-12-2006, 11:46 AM   #8
meathead95
computer illiterate
meathead95's Avatar
i had the exact same problem having to wiggle my key to get it to start so i went to the lock smith and he made me a new key for free (he liked my blazer) and i have no problems at all now
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 07-12-2006, 12:15 PM   #9
Green Monster
I have new keys, but they are even worse. Maybe I'll try again. I'll try the lubricant trick too.
