Old 08-06-2002, 12:09 AM   #1
minibike
minibike's Avatar
69 rear axle to 5 lug
I have a 69 12 bolt coil spring 3.73 axle. I would like to convert it to 5 lug, but have heard the 5 lug axles are longer than the 6 lugs. Anyone know how to do this swap?
minibike is offline   Reply With Quote
Old 08-06-2002, 07:50 AM   #2
JimKshortstep4x4
Smile
You have some options to change to 5 lug. You can swap in a 71-72 complete rear end, go with after market axles, or have your axles redrilled for the 5 lug pattern.
Jim
Old 08-06-2002, 09:39 AM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
You can use axles from a '73 1/2-ton which are the same length as the 71-72 axles. Any of these would require you to use a spacer to adapt the axle length to fit the housing. I don't believe any vendors are producing the spacers for this application. Maybe someone reading this post will consider it, knowing the application will be limited to the '65-69 rear axle assemblies.
1970 axles are the same length as the 71-73 axles, but still have 6-holes. This makes it easy to convert them, IF you can find one to use.
Member Nr. 2770
Old 08-06-2002, 09:45 AM   #4
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Only some of the '70 axles are the same length as the '71-2's. The early '70 rears were the same length as the 67-9's. GM must have been using up surplus stock. I thought the '70's were the same too, until I bought a 3.73 posi rear out of a '70 and it was a different width than my '72 rear..................JB
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 08-06-2002, 12:36 PM   #5
Low69CST
You could send your current axles to be redrilled and the drums around 100 plus shipping
You can order new axles, and drums, over 300 plus shipping.
You could get a 71-72 rear end and switch, but I think brake hoses are different and you don't know how good the ring and pinion will be.
Or you could make spacers and put 5 lug axles in your housing and make new brake lines.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 08-06-2002, 01:10 PM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
First off make sure the axles you have really are shorter. I pulled an axle from a 69 C-10 and it measured the same as the 70-72 axle. I didn't go as far as finding the codes to make sure it was a 69, but everything sure looked like it had been there for 30 years. You never know what has been changed on a truck after 30 years of driving.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 08-06-2002, 01:15 PM   #7
minibike
minibike's Avatar
I really appreciate all the good advice from everyong. The drilling option sounds good...who provides this service?
Old 08-06-2002, 03:25 PM   #8
Low69CST
Moser Engineering in Portland Indianna is the one who people send them to.
Old 08-07-2002, 01:21 AM   #9
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
I went to newer axles in my '66 (same as 69). They are about 1 1/4" longer. I spaced out the backing plates with large nuts!. Sounds stupid, but I have about 20K miles on the set-up, works great. Only problem is that dirt can now enter through the space between the backing plates and the axle housing. I work construction, and drive on rough dirt daily, and no problems.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 08-07-2002, 06:17 PM   #10
67 SS
On the 69 and earlier rearends with 71 up axles how much of the axle race is the bearing riding on?I know there's no problem with a 70 rearend.By the way, don't just throw axles out of a 70 out the door.They interchange with 73 up 4WD with 12 bolt.They would be easy to get rid of.Also why they cost a little more.
67 SS is offline   Reply With Quote
Old 08-07-2002, 07:41 PM   #11
minibike
minibike's Avatar
I'm getting a 71 rear end with 5 lugs. It appears like the bearings will be barely on the end of the race on the shaft. I'll just take my new bearings and other parts (wheel cylinders) and put in the old 71 housing with the 5 lug axles. I had already blasted and powder coated my 69...live and learn.
69 SWB
LT1/4L60E
www.classicplace.com
Old 08-07-2002, 07:42 PM   #12
kaycee
kaycee's Avatar
I put a set of 76 5 lug axle in my 70 .I made 2 spacer plates out of 1/2" steel plate and bolted them to the backing plate works great.Plus they will accept any type of wheel I am running the 15x8 ralleys,I thought about having mine redrilled but the rims would not fit over the center hub on the 6 lug axle.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 08-15-2002, 08:30 PM   #13
minibike
minibike's Avatar
solution!
I found a combination that looks like it will work. The 69 housing with the stock 69 backing plate, 71 axle which is about 9/16" longer. If you use the stock 71 drum, there is a gap between the backing plate and the drum. I used a 74 drum and it meets up perfectly.
69 SWB
LT1/4L60E
