07-14-2006, 09:46 AM | #1 |
WTB Factory Air Conditioning System or Alternative
Does anyone know where I could get a complete factory air conditioning system or an aftermarket one that looks like the original? I've looked at the aftermarket products from nostalgic air, classic auto air, vintage air and old air, and they just don't look original enough, especially under the hood. Thanks for your help
07-14-2006, 10:07 AM | #2 |
Re: WTB Factory Air Conditioning System or Alternative
Im not sure about a new factory setup but HERE is an original one for sale on Ebay minus the compressor.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
07-14-2006, 11:57 AM | #3 | |
It will still need at minimum: Condenser $175, Compressor $200, Hoses $90, Expansion valve $40, Vacuum Tank $20 among other things |
07-14-2006, 12:03 PM | #4 |
Well now you are getting closer to the cost of the low end aftermarket setups. It might be more cost effective to just buy something from Old Air or the like. Anyone else got an opinion or pointers?
07-14-2006, 12:23 PM | #5 |
I would even consider and probably prefer to buy a parts truck with a complete A/C system.
07-14-2006, 12:33 PM | #6 |
Every time I take something apart and put it back together I have extra parts!
07-14-2006, 06:00 PM | #7 |
If your truck is set up for factory ac, I would use factory. Aftermarket works but, in my opinion, not as good. In fact, the only way I would use aftermarket again in any vehicle is if the vehicle wasn't an original factory air vehicle. But, I never plan on buying another vehicle that wasn't factory ac to begin with so I guess this means I will never be buying aftermarket ac again. Problems I experienced with aftermarket was fan motor was too loud because it's in the cab, fogged windshield everytime I turned the ac on in morning or evening. Plus the cooling wasn't any better but about the same as factory. Plus I didn't like the way the naked fire wall looked after the original ac components were removed (but lots of folks like this look)
07-14-2006, 09:51 PM | #8 |
Too Dumb To Know Better
If you have the complete setup, it;s not too bad. You will have to modify the firewall as the holes are different. The center vent is not too hard to cut. I don't like the factory ball vents so I went with these.
07-14-2006, 10:12 PM | #9 |
I like the factory ball vents. What's the best way to cut out for the center vent?
07-14-2006, 10:19 PM | #10 |
You need to find a parts truck or find someone who is parting out an original A/C truck. Check with Teeitup, I think he has some good original parts.
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
07-14-2006, 10:43 PM | #11 | |
07-14-2006, 11:22 PM | #12 |
Active Member
I just bought this factory set up from a Local Mechanic For $50.00
He has an Older Chevy sedan that he Incorporated this set up into, And told me that I should be able to do the same with my Non A/C Blazer. I need the compressor, Brackets and Condensor But My quest for Cheap A/C Has Begun. |
07-15-2006, 12:10 AM | #13 |
The last time I was at justascatch, he had several. Might try PMing him.
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
07-15-2006, 12:15 AM | #14 |
low 'n slow, did your truck come with that battery gauge? if not, where'd it come from?
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
07-15-2006, 11:51 AM | #15 | |
07-15-2006, 01:55 AM | #16 |
Not really all that hard to install a/c into a non a/c truck.... should have templates for left and right dash outlet balls, upper center outlet and possibly firewall template.Does simplify, if you choose to have outside air only as I did... I also installed a separate switch controlling the compressor. Separate switch allows mixed a/c and/or heated air thru any of the outlets you choose....did mine over ten years ago; still works great The evaporator, and condensert can be from most any GM vehicule of that era. ( You will need the original evaporator case, however......Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
