Old 07-20-2006, 09:32 PM   #1
74Chevy74
If you Z the frame do you raise the tranny xmember up the same???
Been digging through a lot of these posts and didn't find much on this question I have. I have a 74 that's getting ready to be cut! I was wondering though if you Z the frame 2.5" then do you also need the tranny mount to be moved up 2.5"? I'm pretty sure motors need to be at certain angles for oil circualtion and stuff, what are you guys all doing?
74Chevy74 is offline   Reply With Quote
Old 07-20-2006, 10:13 PM   #2
brandonh
brandonh's Avatar
Re: If you Z the frame do you raise the tranny xmember up the same???
yes it does need to come up, im zed im frame 3 1/2, and im either going to build and new tranny mount or try to cut the other one to work, if u dont the motor wont sit at the right angle at all and like u said the oil wont circulate right then u know what happens BOOM
Brandon
67 chevy CST
68 chevy stepside US ARMY truck
69 chevy longbed green and white Custom10
05 Honda Rancher AT with 26 inch ITP 589's
2008 Chevy crewcab vortec max 4X4 pickup
1969 Chevrolet layin frame Project Fools Gold
http://67-72chevytrucks.com/vboard/s...d.php?t=257593
brandonh is offline   Reply With Quote
Old 07-20-2006, 10:55 PM   #3
Rokcrln
Rokcrln's Avatar
It is the water that you will have a problem with and air pockets getting traped and causing hot spots. What you want is your intake manifold where the carb bolts on to be level.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 07-20-2006, 11:44 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
Kevin
LFD Inc.
Like Kevin said, you want the carb base on the intake to be level. Set your truck up at ride height and level the motor accordingly, then modify the trans crossmember/mount as needed.
PBFAB.COM is offline   Reply With Quote
Old 07-21-2006, 12:39 AM   #5
E's c10swbfleet
E's c10swbfleet's Avatar
but u can start off with a lowwer engine mount,one that sits on the xmember only then i think its only a round 1 1/2 raise on the tranny.
E's c10swbfleet is offline   Reply With Quote
Old 07-21-2006, 01:05 AM   #6
74Chevy74
Thanks for the input from all of you. Do you know who makes these mounts? Are they direct for the truck or custom?????
Old 07-25-2006, 09:35 PM   #7
7deuce
Sold! 2 days after finished
7deuce's Avatar
I JUST bought a set of these motor mounts and got them in today. And I dont think that they are too different from the stock ones. ALSO the driver mount that I got, the tube that is welded to the big pipe that the motor bolts too was angled up 3/8 of an inch more than the passenger mount. It was 5.30 ohio time and I was 30min shy of getting ahold of them. Ill post tomarrow if I had any problem getting a replacement mount. This will tell if the company is even worth dealing with.
7deuce is offline   Reply With Quote
Old 07-26-2006, 09:54 PM   #8
7deuce
7deuce's Avatar
The shipped a new set out NO PROBLEM. I would buy from them again. Great to deal with.
Old 09-10-2006, 04:50 AM   #9
wannabeburbowner
wannabeburbowner's Avatar
Do you have to modify the tranny tunnel at all when you z the frame 3-4" and raise the tranny??
71 Chevy Long Bed (gettin' bagged)
84 GMC K1500 (Sold)
85 Monte Carlo SS white w/gray int. (being a dumba** and totaled it )
85 Monte Carlo SS clone T-top (Sold)
72 Chevelle-tubbed
64 Buick Sportwagon
wannabeburbowner is offline   Reply With Quote
Old 09-10-2006, 03:11 PM   #10
Draggin79
Draggin79's Avatar
yep...
Draggin79 is offline   Reply With Quote
Old 09-10-2006, 08:11 PM   #11
laidout86
hey draggin how much did u z the frame????
laidout86 is offline   Reply With Quote
Old 09-10-2006, 09:48 PM   #12
7deuce
7deuce's Avatar
Man, looks like youll be hackin up a bench seat like I did unless your going to roll buckets. Looks good man, keep em comin.
