Old 07-29-2006, 08:56 PM   #1
Sgt.Booya
Sgt.Booya's Avatar
Re: "Power Brake Conversion" Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=163387
Original post by Farside847 in July 2005. Excellent post lots of pictures and step by step instructions! Thanks very much farside847, I followed you directions to the "Tee" and this conversion worked for me. Just a bit more info I can add for the I6 guys and drum/drum applications.
1) I ordered an entire PB, M/C and prop valve from a 72 C10. Thanks BillsBowTie
Drum/Drum
2) For the drum/drum. I have I kept the drum/drum prop valve that was on my truck and removed the disc/drum prop valve that came with the new PB. (I'll keep the disk/drum prop valve for when I upgrade to disks up front.)
I6 Engine Differences
3) There is only one vacuum location I could find on the intake. I had to get creative at the Home Depot and figure out a way to "T" this vacuum source with the transmission and the new PB. I just used brass plumbing fittings.
4) When the PB is installed your stock air cleaner will no longer fit. I got a smaller Mr. Gasket Air Filter from Canadian Tire.
5) You'll also need to go and get a new oil breather cap for the valve cover unless you prefer my ghetto look!!
6) One other thing, don't forget to adjust the brake light activation switch as the pedal will sit lower than it did before. My brake lights were on all the time until I adjusted it correctly.
7) Also since you'll be disconnecting the brake line from the M/C of course you'll need to bleed the entire system.
Just just back from my test drive. Works great. Now I'll need to go to the gym to get my leg workout
Here's a photo of the installed PB:
(Click see see bigger photo)
If you keep and open mind you never know what might drop in.
1970 Chev C10 SWB, "250 turbo thrift"
Sgt.Booya is offline   Reply With Quote
Old 07-29-2006, 09:19 PM   #2
JameslovesJammie
God Bless Mr. T
JameslovesJammie's Avatar
No pic, dude!
Like a midget at a urinal...sometimes you must stay on your toes.
JameslovesJammie is offline   Reply With Quote
Old 07-30-2006, 07:33 AM   #3
Sgt.Booya
Sgt.Booya's Avatar
Not sure why the picture was not working. I posted it another way. Click the smaller picture for a link.
Old 07-30-2006, 12:18 PM   #4
70C10Toejam
Hellasick
70C10Toejam's Avatar
pic worked fine for me.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
