07-30-2006, 04:50 PM | #1 |
4" front drop?????
If I drop my 69 4" in the front am I gonna have any troubles with the front sway bar?
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
07-30-2006, 04:59 PM | #2 |
Re: 4" front drop?????
Not if you get ECE lowered mounts for your sway bar. Mine is dropped 4.5". My lower "A" arms at the lowest point are only 3.5" off the ground.
07-30-2006, 05:04 PM | #3 |
I suppose i should mention i am going with 2.5" drop spindles
07-30-2006, 05:10 PM | #4 |
My truck has ECE 2.5" drop spinds and 2" drop Ground Force springs. You should be fine. The ECE lowered mounts are not too expensive and it is possibe that you don't even need them. ECE has great Cust Serv...talk with them when you order your Spinds!
07-30-2006, 05:21 PM | #5 |
Could I see a side shot of you truck? I am undecided if i want to go 4" or 4.5" in the front.
07-30-2006, 05:44 PM | #6 |
Sorry, I don't have a very good side shot. Truck is still in build process and has only been outside of the garage with the bed off. Maybe someone else can post a nice pic of a 4" front drop???
07-30-2006, 07:08 PM | #7 |
I saw a trick where a guy drilled out the rivets on the original sway bar mounts and then mounted the sway bar on top instead of on the bottom. Pretty ingenious and cheap! Wish I had thought of it.
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 07-30-2006 at 07:14 PM. |
07-30-2006, 07:36 PM | #8 |
like inside the original mounts?
07-30-2006, 07:39 PM | #9 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
