Old 07-31-2006, 02:28 PM   #1
1967C10
1967 C10 bbc engine swap
I'm getting ready to replace a 350 with a 454 in my 1967 C10. Anyone have any experience with this engine swap? My 1st concern is the motor mounts: Can I use the 350 motor mounts on the big block? If not, where can I buy big block mounts? Most of the parts stores around here don't have a clue. BTW, the '77 Suburban motor mounts are still bolted on the big block.
Also, will there be any clearance problems with the HEI, short valve covers or headers?
Any info would be appreciated as this is my first try at an engine swap.
1967C10 is offline   Reply With Quote
Old 08-01-2006, 12:46 AM   #2
shadetree
shadetree's Avatar
Re: 1967 C10 bbc engine swap
Go to GMCPauls web site, and window shop, then call GMCPaul. His knowlege & array of parts will amaze you, and save you time and $$$$. Tel Paul I said "hi".
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 08-01-2006, 02:46 AM   #3
1967C10
I'll give that a try, but I already decided to try and use the 350 towers and mounts that I already have. If it doesn't fit then a small block is going back in. I'm not spending hundreds of dollars on big block motor mounts that may or may not work.
