7000 #'s of american IRON
305 mods?
My friend has a "305" 1984 GMC C-15 pickup. He wants to know who makes reasonable priced headers and complete exhaust systems (smog equipped) for a reasonable amount of money (works at walmart so not a big budget). The reason I say a "305" is that it has a 6" tall air filter, and after observing some other things (including a very throaty exhaust note), i'm wondering to myself if it still displaces 305 cubic inches.
Re: 305 mods?
Any small block headers 265-400 will work you need to buy headers per application of what the motor is in, Look into Flow tech afterburners for a smog legal and cheap, edelbrock and doug thorley headers are better but also tough on the wallet, summit makes 50 state headers for trucks also
Re: 305 mods?
You'll have to check the casting number on the back (drivers) side of the engine block to know for sure what engine you have. Check www.summitracing.com for CARB legal headers. I'd check with a local muffler shop for the exhaust...
1977 Chevrolet C10 - 305/TH350, SWB, Stepside, 3/5 drop...work in progress. |
Re: 305 mods?
the VIN indicated 305, but i'll try to check the casting numbers (being they are so hard to get at).
I checked summit and Jegs, but didn't find much that fit a minimum wage budget and would pass smog testing in the dallas area. I reccomended to him to start out with just high flow headers and Cat just clamped then 2" mandrel bent tubing to connect them with side exits ahead of each tire, then headers. |
Right turn Clyde
Re: 305 mods?
Check the front pad under the alternator.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#6 | |
Re: 305 mods?
Right turn Clyde
Re: 305 mods?
![]() If the block has been milled down it wont be there or barley left. I really doubt that the block has been decked. Its directly behind and under the alternator. If you need disconnect the battery and swing the alternator out of the way. Loosen the bottom alt bolt, remove the top one, take the belt off, the alt will be loose enough to turn it left out of the way. Get some carb cleaner and a rag to wipe the pad off to see if there is anything stamped.
