08-01-2006, 05:42 PM | #1 |
10/30/19
Verifing engine #
I have a 327 engine,that is what I was told anyway.Can someone verify the #s for me.The numbers are 3956618.Thanks
Fight the good fight, finish the race, keep the faith |
08-01-2006, 05:47 PM | #2 |
Re: Verifing engine #
According to mortec.com
3956618....350.....69....2 or 4 Bolt main |
08-01-2006, 05:50 PM | #3 |
3956618=
1968-69--302--290HP--4bolt main 1968-69--327--250hp,300hp,350hp--2bolt main 1968-79--350--250hp,255hp,350hp--2or4bolt main Need # off front pad to see which one.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
08-01-2006, 07:04 PM | #4 |
10/30/19
I don't know what you mean by the term,front pad.Above the # it looks like this:
20 GM 3956618 I did pull it from a 68 1/2 ton.
Fight the good fight, finish the race, keep the faith Last edited by kingsolver72; 08-01-2006 at 07:10 PM. |
08-01-2006, 07:14 PM | #5 |
TOTY 2006
Looking at the front of the engine, on the passenger side of the engine where the bottom of the head meets the block, should be a flat machined surface that will have some numbers and letters stamped into it. If you can find that, it will narrow down exactly what the engine is and what it was in from the factory BUT that is assuming that the engine has not been decked as that would remove the stamped numbers. Also, are the heads on it, if so, pull the valve covers and ge the numbers off the heads as that may help as well...
08-01-2006, 07:37 PM | #6 |
10/30/19
O.K. it looks like the # on the front pad is VO218FB.Thanks everyone.
08-01-2006, 08:50 PM | #7 |
TOTY 2006
The engine suffix FB indicates that it is a 1969 327 from a full size car.
This info was from www.nastyz28.com.... |
08-01-2006, 09:49 PM | #8 |
10/30/19
Thanks again John.
