Old 08-02-2006, 06:33 PM   #1
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
rearend eaton ho52 help
how much grease do they hold its the eaton h052.
we had to put 6qts in it one time but it i dont think it was empty then
were putting it back together and cant get the fill plug out.so were going to install one axle and then jack the othe side up and pour grease thru axle tube.
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 08-02-2006, 06:50 PM   #2
bryanw1968
bryanw1968's Avatar
Re: rearend eaton ho52 help
So you're talking about filling up a eaton posi rear end right?
I have a 12 bolt eaton posi 3.73 and it required 2 1/2 to 3 quarts of 85/90 weight gear oil.
6 sounds like a lot unless I'm missing something.
Good luck,
B
bryanw1968 is offline   Reply With Quote
Old 08-02-2006, 09:31 PM   #3
72shadetree
KEEP ON TRUCKING
this is actuallay a eaton rear 3/4 ton 4x4 rear this thing is huge
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 08-02-2006, 10:45 PM   #4
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
This rear is a full floating axle and has the big round 10 bolt cover, almost looks like a big truck axle. I don't know exactly how much it holds, but the easy way to know when it's full is to put gear oil in it till the level is just below the fill plug hole. Now since the plug is stuck I don't think that method will work.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 08-02-2006, 10:55 PM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
6 pints for an eaton 10 bolt. Another way to fill is to remove a cover bolt at the same level as the drain plug. You can squirt warm oil in that way. Put the bolt back in with sealant.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 08-03-2006, 02:32 AM   #6
72shadetree
KEEP ON TRUCKING
thanks
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 08-03-2006, 06:16 AM   #7
Fred hit the nail on the head.What I`ve done in your situation is,put 6qts in the axle tube,then remove the cover bolt at the plug-line to let extra lube out.It`s just a bit quicker.
Old 08-03-2006, 11:08 AM   #8
bryanw1968
bryanw1968's Avatar
I gotta stay outta these 4x4 3/4 ton threads!
hehehehehehehehe
Old 08-03-2006, 10:46 PM   #9
Same rear in 20 series 2wd.
Old 08-04-2006, 12:18 AM   #10
wibilly
wibilly's Avatar
speciak k why do you use twice as much lube as fred? then drain it back out
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 08-04-2006, 05:15 AM   #11
OOps...I meant pts,not qts...misprint,good eye.I was giving an easier way,but the "same" idea.
