Old 08-04-2006, 01:14 PM   #1
incoma
incoma's Avatar
gas tank cleaning
I've run a search and read several threads where bolts, chain, etc were put into a tank and used to clean out the rust. I did the same thing ..and ran it through a pressure washer for several minutes. Question is, will this keep it clean for a few years, or do I need to have it sealed up? Local shops want $150 to clean and seal the tank. For that price, I could buy a new tank.
Will the cleaning that I've done last for a few years? How long does it take for the tank to get rusty and nasty again on the inside?
"Green Monster" (Red Sox fan)
1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension
incoma is offline   Reply With Quote
Old 08-04-2006, 02:25 PM   #2
67chevemall
67chevemall's Avatar
Re: gas tank cleaning
Buy the summit 16 gal fuel cell.$160
Or pay the $150. I've paid it a few times and it always lasted as long as I had the truck. They clean it out, pressure test it, weld spots, dip it in por-15
=better then new.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 08-04-2006, 03:44 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Agreed 100%
Don't let them dip it onless they will replace it when it starts leaking at the seams later. (talking the acid dip... not POR)
Old 08-04-2006, 03:55 PM   #4
1969K10
1969K10's Avatar
We cleaned out my buddies gas tank to his '68 using similar method. then we installed it, filled it up with gas & a gas dryer (just in case). We still went thru fuel filters alot. The more it was driven, the longer they lasted. It took a little over 2 months to get it to quit going thru fuel filters... Had one on the carb & on in-line. The carb one was changed once a month, it was the other one that we kept going thru...
1969K10 is offline   Reply With Quote
Old 08-04-2006, 04:46 PM   #5
incoma
incoma's Avatar
1969K10 - Thanks. That's the type of info I'm after. The whole purpose of me cleaning this thing out was to stop the fuel filter clogging problem. Its tough to drive the truck into town if you don't expect it to make it all the way back!
Old 08-04-2006, 06:56 PM   #6
RicksTrucks
RicksTrucks's Avatar
Sometimes it depends upon what they line it with after cleaning. I have heard stories of the liner coming off if not properly applied.
I think where it will rust, after your own cleaning process, will be if it is left close to empty a lot and the air gets to it and starts to rust again.
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 08-04-2006, 07:42 PM   #7
jacobs
jacobs's Avatar
I cleaned a rusty fuel tank last spring by placing about 10 pounds of drywall screws in it and shaking and rocking it back and forth. It takes time but does a good job. Be prepaired to use a magnet to get all the screws out. I rinsed it out with water when finished and then set it out in the sun to dry.
jacobs is offline   Reply With Quote
Old 08-04-2006, 10:07 PM   #8
72rustbucket
72rustbucket's Avatar
I took mine to a radiator (sp) shop and they cleaned for like $40. Had it done like 6 months ago. I know it will rust again but not for awhile. But will convert to under the bed in a few months.
72rustbucket is offline   Reply With Quote
Old 08-04-2006, 10:07 PM   #9
72rustbucket
Old 08-04-2006, 10:54 PM   #10
John Fabris
TOTY 2006
John Fabris's Avatar
Eastwood sells a cleaner and coating kit which is what I used on my tank....
Just another option...
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 08-07-2006, 10:30 PM   #11
incoma
incoma's Avatar
Well, pressure washing the inside of the tank seems to have solved the problem. I'm still getting a bit of trash in the filter, but that my have already been in the line. Looks like it knocked out all of the big stuff and left it clean enough for me to get by for a while.
