08-06-2006, 09:59 PM | #1 |
Designated A-hole!
What's a Driveshaft for TH400 in a SWB cost?
The title says it all.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
08-06-2006, 10:19 PM | #2 |
Re: What's a Driveshaft for TH400 in a SWB cost?
if i had the stock drive-shaft, i would just put the turbo-400 yoke on it.
salvage yard parts. cheap. if stock drive shaft is too long now? have drive-line shop cut it and add proper front yoke. they balance it too, p.s if i ever sound condescending in my posts just blame all the good sleep i get and quality coffee i drink. i never mean to talk outside of what i know. i like this web site. life is good. |
08-06-2006, 10:27 PM | #3 |
Designated A-hole!
I really want a one piece, and evidently this tranny is the HD version with the bolt on yoke. Have to do some checking on that.
08-06-2006, 10:45 PM | #4 |
It can be converted to a slip yoke style. Otherwise, You'll need a 2 piece shaft. It's gotta be able to slip somewhere.
08-06-2006, 10:55 PM | #5 |
Designated A-hole!
That's what I figured. I wonder if I can just take the bolt out of the yoke that's on there and let it slip a little?
08-07-2006, 12:29 PM | #6 |
On the road
Krue,
You won't be able to use your bolt on yoke without the bolt because it will leak unless you plug it somehow, but you can use a regular slip yoke in it's place. Also there's an o-ring up inside on the output shaft you will have to remove to allow it to slip. You could possibly shorten your existing driveshaft depending on it's construction, I have done this a few times.Take it to a driveshaft shop and let them check to see if they can do it. Mike
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
08-07-2006, 04:15 PM | #7 |
Designated A-hole!
The slip yoke I have is way too small to work with the tranny out put on the 400 I have, do they make a slip yoke to fit it?
08-07-2006, 06:00 PM | #8 |
Yes they do. I've got a long slip yoke if you need one, cut it to length!
08-07-2006, 10:56 PM | #9 |
I used the back half of the driveline out of a 78 chev 3/4ton crew cab. It was 3/4" too long, had it shortened, but I may also have my engine mounted further back then you do.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop 70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress |
