Old 08-06-2006, 11:28 PM   #1
Daubs
Daubs's Avatar
Bed swap...wood for steel (?)
My K-20 has wood bed that is in pretty good shape. I'm pretty sure this truck is going to be sitting outside it's entire life and get used for hauling stuff that would really tear up a really nice wood bed. Thinking about swapping out for a steel bed that I could possibly get Line-X'ed or something similar.
The questions are these:
  • Could I convert the wood bed to steel?
  • If conversion isn't easy or possible, you think someone / anyone would trade me a steel bed for my wood bed?
Thanks, D.
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 08-06-2006, 11:52 PM   #2
Green Machine
Green Machine's Avatar
Re: Bed swap...wood for steel (?)
Your will retain your bed sides, wheel tubs and tailgate, everything else gets swapped out. You will need the front bed panel from a steel bed (I have one), the entire bed floor with the steel floor rear cross sill. If that wood bed floor is really nice I might be interested, sorry, I have no steel bed floor, just a front panel.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-07-2006, 09:04 AM   #3
lilred67
lilred67's Avatar
steel...i replaced my wood stepside bed with steel.i used 3/16" sheet iron instead of a factory steel bed floor.with the extra wieght it rides better and gets better traction on wet roads, etc.
lilred67 is offline   Reply With Quote
Old 08-07-2006, 01:24 PM   #4
dennislbrooks
dennislbrooks's Avatar
agree with lilred67 above -- I used 14 ga deck plate ---for a short bed about 150 pounds. mine was steel to begin with tho
dennislbrooks is offline   Reply With Quote
Old 08-07-2006, 09:20 PM   #5
Daubs
Daubs's Avatar
So you are saying I can convert my wood bed into a steel bed with correct parts(?). Front panel is already dented and needing replacing, so I got taht going for me.
Wood in current bed is beginning to buckle and swell from sitting outside.
Old 08-07-2006, 09:29 PM   #6
Eddie H.
Eddie H.'s Avatar
I have a complete steel bed that is already disassembled that I could help you out with if you weren't so far away.
If you happen to be coming through the Dallas/Ft worth area, let me know.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 08-07-2006, 09:30 PM   #7
BarryB
BarryB's Avatar
I would consider trading the pieces you need to swap out for your pieces. I have the front panel and the rear cross section . Other than these pieces I believe everything is the same. I might possiblly have the steel floor also for a long bed. Shipping wouldn't be to bad for front panel and the rear cross piece.
BarryB is offline   Reply With Quote
Old 08-07-2006, 11:07 PM   #8
chipflyer
chipflyer's Avatar
I have a pretty good steel floor that I was going to add to mine but if you have wood bed parts that aren't to bad I might trade. What kind of shape is your stuff in? Not worried about the wood, how are the cross braces?
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
