08-09-2006, 07:57 AM | #1 |
Wheelwell gravel shields
I am putting together a 71 fleetside short bed, does anyone install the (2)gravel shields that go on the rear of the tubs? I'm sure it helps with stone chips dings etc. How about the (2) braces that go from the cross sill to the bedside to at the bottom to reduce flexing? Anyone have pictures of how these are mounted? Any help will be apprecitated. Thanks
Richard Dobson |
08-09-2006, 11:23 AM | #2 |
Re: Wheelwell gravel shields
if i think of it when my daughter gets up i'll get her to post some pics for you. im' computer illiterate
common sense isn't so common anymore Last edited by wibilly; 08-09-2006 at 11:38 AM. |
08-09-2006, 12:31 PM | #3 |
its all about the +6 inches
You defenantly need the braces, my old SWB had them missing and the lower portions of the bedsides flapped and vibrated enough to rip. (this was solid sheetmetal with no rust or filler)
08-09-2006, 12:56 PM | #4 |
Thanks Longhorn Man, I was trying to mount the braces and ran into a problem. I have them going from the second cross sill from the front of the bed (on the front bed panel side of the sill) to the bed side at the bottom. On side goes on with a little bit of a push on the beside outwards. The otherside misses by at least 1/2 to 3/4 inch, should I just drill a new hole. I checked the bed for squareness etc. Thanks for any available advice. I am also needing advice on how the gravel sheilds mount, do they go in behind the wheel well lip or in front?
Richard Dobson |
08-09-2006, 04:45 PM | #5 |
The LuvShack Garage
Seeing as I have never mounted mine either, pic's would nice
08-09-2006, 05:04 PM | #6 |
Pics
08-09-2006, 05:11 PM | #7 |
The LuvShack Garage
Cool, where's the Drivers side?
08-09-2006, 05:21 PM | #8 | |
08-09-2006, 05:35 PM | #9 |
The LuvShack Garage
Gotcha
08-11-2006, 12:19 PM | #10 |
I have already painted the gravel shields and I wanted to know how they mount. Looks like I have an alignment problem with the hole at the bottom of the bedside, the one on the top inside the tub is OK. I sure don't want to scratch up new paint but I don't want to leave them off either. They do lap over the bedside instead of going to the inside of the wheel opening lip right? Thanks
Richard Dobson |
08-11-2006, 12:54 PM | #11 |
Before you drill, the guards go behind the wheel not in front of it.
I think it's the third cross-sill from the rear (if you count the rear sill). Dano
'69 Fleet It ain't yours, if you didn't build it! |
08-11-2006, 01:02 PM | #12 |
Thanks Dano69c10, I knew that they go behind the rear wheel, but do they lap over the bedside lip or under it? Thanks again.
Richard Dobson |
