Old 08-09-2006, 01:18 PM   #1
67ChevyRedneck
67ChevyRedneck's Avatar
Aftermarket A/C condensor placement?
I know this is a ways off but I plan on installing either a vintage or old air kit on my truck next year...the reason for posting now is in about 2 weeks I hope to install my new external tranny cooler. It is the one pictured below and I am going to mount it vertical behind the grill. I don't want to mount it, get the lines bent and have to move it when I install an A/C kit next year, so pics of where y'all put your aftermarket condesors would be great! Do the go the whole way across the radiator opening...etc... I just don't want to have to move the tranny cooler again. Y'all are such a great help, thanks!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-09-2006, 01:29 PM   #2
john
member #16
john's Avatar
Re: Aftermarket A/C condensor placement?
You should be safe if you mount it on the drivers side of the rad support next to opening. The condenser and dryer and lines pretty much take the room on pass side. Unless it is fairly short and can mount in front of center of batt area. This pic shows the dryer and lines.
john is offline   Reply With Quote
Old 08-09-2006, 04:44 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Drivers side is pretty much wide open
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-09-2006, 04:44 PM   #4
see ten
WTB this ad
see ten's Avatar
+1 on the drivers side install of your cooler. If you just have to have it on the passenger side I would run the lines out a new hole below the factory hole in the core support (below the battery box). As long as you mount your cooler to the left of that hole(passenger side) you shouldn't be in the way of the A/C lines. Here's a shot I had on file of the drivers side.
see ten is offline   Reply With Quote
Old 08-10-2006, 08:44 AM   #5
67ChevyRedneck
Thanks for the replies everyone. Driver's side it is!
LUV, is that an aftermarket or factory condensor? I'm curious as to how far the aftermarket one comes over. It looks like I need to mount it to the right of the "vertical bump out" in the grill (see arrow) and I should be ok. BUT will it get enough air flow being behind the turnsignal and not directly in front of the radiator??? Don't want to roast another 700R4 I will be running the tank integrally with the radiator. After a lot of reading I've decided this will be the best/safest way to go, It will be running through 2 coolers, can't go wrong there!
Jesse James
Project "On a Dime"
Old 08-11-2006, 12:30 AM   #6
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I stuck an Aluminium Parralell flow condensor in the stock position.
I just had to fab up 4 small brackets.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 08-11-2006, 08:09 AM   #7
67ChevyRedneck
Sweet, thanks, I'll just assume the whole area in front of the radiator is going to be taken up.
Jesse James
Project "On a Dime"
