Old 08-16-2006, 01:49 PM   #1
pkj
springs or spindles?
i was advised that i could use springs to drop my 68 3/5. i want to avoid using a drop spindel because i want to maintain my drum/drum set-up.when i started to order everything gmc paul said i may not be abel to properly allighn truck. what can i do? i dont want less then a 3/5 drop and cant swing a spindel-disc set-up now. any ideas? thanks every one.
pkj is offline   Reply With Quote
Old 08-16-2006, 02:15 PM   #2
Inthuwind
Straight jacket required
Inthuwind's Avatar
Re: springs or spindles?
Can you get your hands on a 72 front clip with the spindles/discs on them for cheap? Or is this not what you want to do? I say if you can't, go with the lowerer coil setup, or cut your existing coils. There are a few threads here on cutting coils I believe. Hope this helps
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 08-16-2006, 02:18 PM   #3
Joe67
67 is sold
I have also heard fron 3" drop springs have alignment issues.
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 08-16-2006, 05:41 PM   #4
pkj
dont have time or good location for a clip swap. has anybody found a solution to using the 3 inch springs? what are the alignment issues? how severe are they? i am not looking for high speed cornering. i want the truck to handel and ride nice. springs are original wore out so i dont want to cut.
thanks
Old 08-16-2006, 07:02 PM   #5
crazy longhorn
Fabricate till you "puke"
I think Paul told you "square up" on the springs, much more than 2 - 2 1/2" will cause problems. He!!, if you go 2 1/2" spindles, its only about a bill more than the springs.... you can chop a full ring off the bottom of the springs, & figure about 2 1/2" drop. If I do the math, that looks like 5 " on the front, but its a tad more pricey. You can keep the 6 lug wheels if you like, Paul has the rotors to fit Best of luck, L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-16-2006, 07:30 PM   #6
see ten
WTB this ad
see ten's Avatar
This truck is my buddys and it has 3" drop springs in front. He claims it's aligned but I dont know if it is or not. I do know that his springs will fall over or out when he jscks up the front end. He is wanting to remove them and put in drop spindles.
see ten is offline   Reply With Quote
Old 08-17-2006, 12:46 PM   #7
XXL
Seņor Member
XXL's Avatar
[QUOTE=see ten]This truck is my buddys and it has 3" drop springs in front. He claims it's aligned but I dont know if it is or not.
It's probably completely shimless on the UCA's, or worse... maybe even shaved a little on the cross shafts.
XXL is offline   Reply With Quote
Old 08-18-2006, 12:00 PM   #8
pkj
okay so you guys favor spindles. now i still want 3/5 or more cool 4/6. i have drum/drum set-up that wont work. if i go disc, then i want to go power at same time. is ther a complete kit available or do i need to piece meal? this is starting to sound expensive.but i dont have time to piece it togather. any help on laying this out before i start would be a big plus. thank you
Old 08-18-2006, 03:14 PM   #9
XXL
Seņor Member
XXL's Avatar
Buy the entire crossmember and attached suspension out from under a 73+ truck. It's a direct swap for what you've got. Add mc, booster, prop valve, and smaller brake line down to the tee in the driver's side frame channel, and you're all set.
Old 08-18-2006, 04:07 PM   #10
Shane
Shane's Avatar
You will also need ART decals.
They add oodles of "cool" to lowered vehicles.
Shane is offline   Reply With Quote
Old 08-22-2006, 01:48 AM   #11
jimmydean
jimmydean's Avatar
I got my kit on sale for $599. It comes with the full drop spindle disc kit, back plates, ball joints, and tie rod ends. It's a 6 lug kit as well. I got my power booster off a 'Burb on Craigs List for $20 with the disc/drum valve still attached.
I decided to get bags because I wanted to be able to haul crap as well as lay low when I feel the need. It's a chunk of change for sure, but the end result is so worth it!
jimmydean is offline   Reply With Quote
