08-20-2006, 05:56 AM | #1 |
72 Brake Warning Light
Am I missing something or is there no brake failure warning light in a 72 C10?
08-20-2006, 06:04 AM | #2 |
Re: 72 Brake Warning Light
There should be a brake light in the lower left of the fuel gauge that comes on with the key. I would check the bulb first and if that is good check the sender unit that is on the prop valve.
Jim |
08-20-2006, 11:51 AM | #3 |
its all about the +6 inches
yup, a brown wire should be plugged into your proportioning valve. With the ignition switch on, the light will (should) come on if you ground that wire.
08-21-2006, 02:43 PM | #4 |
Man, I must be getting old, I did not see it. OK, lazy is more like it. Just never noticed it coming on when cranking. I grounded at the P valve and it works. I watched while cranking and it came on. Sorry to have wasted server space!
So I see no switch on the E-brake assembly but on the wiring circuit it shows #209 Purple. I am guessing it ain't there since I can't find it. Anybody install a switch on the e-brake and splice into the circuit? Wife has problem understanding the e-brake release thing unless the light tells her... Last edited by crustysarge; 08-21-2006 at 02:46 PM. |
08-21-2006, 03:16 PM | #5 |
I've been wanting to do this to mine, my first one had a micro switch installed. It's a fairly easy mod...but since my parking brake really doesn't work, it seems kinda stupid to rig up a light.
Every GM truck i have messed with (in that area), that wire is tan, not purple. Just for the record. |
08-22-2006, 07:00 PM | #6 |
Black 72 Chevy
I had the same problem the wife driving my truck with the E-brake still active. I installed a reed switch and splice the tan wire. No drilling was needed to install the switch, only double sided tape. If pics are needed, I can post some.
08-23-2006, 09:25 PM | #7 |
Not a bad nut after all..
Please post pictures! This is a great idea.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
08-25-2006, 09:20 PM | #8 |
Black 72 Chevy
Will post them this weekend.
08-26-2006, 07:34 PM | #9 |
Black 72 Chevy
Here are the pics.
The reed switch cost me about $4. |
08-26-2006, 07:39 PM | #10 |
Black 72 Chevy
The black/white wire (ground) is connected to common and the brown wire is connected to NC.
08-26-2006, 10:17 PM | #11 | |
Where can I purchase a reed switch?
08-27-2006, 01:30 AM | #12 |
Black 72 Chevy
Badpeanut
The tan wire is splice into the tan wire from the proportioning valve. The reed switch I bought from Fry's Electronics. |
08-27-2006, 07:35 AM | #13 |
The LuvShack Garage
That's a mod, and inexpensive too
08-27-2006, 02:57 PM | #14 |
Any 70's GM car that has a switch should work. I looked at my 77 Trans Am and the brake assembly is very similiar. It has a sping loaded switch mounted with a small bracket and works like a brake pedal switch circuit. Be easy to do.
