08-21-2006, 03:03 PM | #1 |
Noise at 30mph
Around 30mph there is a whining noise in my 65 C10. It sounds a lot like the big oversized off-road tires running on the highway. It only starts at 30 mph and stops when I let off the gas. I thought maybe the rear end need more oil, so I brought it to a lube shop to have the oil changed in the engine & rear end. The rear end was bone dry. Well, it now has oil but the noise is still there. It’s weird because it is only noticeable when I press the accelerator. Any thoughts?
Chance |
08-21-2006, 04:26 PM | #2 | |
Re: Noise at 30mph
I suggest either a new ring and pinion or pick up a third member or rear end from a junkyard. Either that or simply put up with it and hope........ RD
Sleep well tonight, The Sandman |
08-21-2006, 04:57 PM | #3 |
C10 now is a GMC
Re: Noise at 30mph
It's the EXACT same thing with mine, but mine did have oil in it.
The noise sounds like it was coming from the trans(vibration traveling up the driveline). The way my Dad & I found it was by putting the rear up on jack stands, in gear with wheels moving, and using a dowl as a stefisscope(sp) (doctors uses it on there patiants ) starting up at the transmission, working are way to the rear end. It turns out the left outer bearing is wore out, you can wiggle the wheel. It started after taking a 20 mile drive with a small truck load of brick paver stones. If you're going to be replacing the 3rd member guts, for a piece of mind replace the outer bearings on the axle shafts & seals too. I'm just going to replace the whole axle with a good used unit. David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project Last edited by Chevyboy1962; 08-21-2006 at 04:58 PM. |
