Old 08-22-2006, 03:38 PM   #1
Chevyman680063
Chevyman680063's Avatar
Gas pedal is loose
Does anyone know what I need to get to fix my gas pedal linkage? The rod running from the gas pedal and through the firewall started wobbling around on my truck a few months ago. The rod running through the firewall is connected securely to the line running to the carb. linkage so I know that's not the problem. From what I can tell it is loose at the firewall. Is there a rubber bushing that helps to hold the gas pedal rod in place on the firewall and where can I get what I need to fix it?
Chevyman680063 is offline   Reply With Quote
Old 08-22-2006, 05:07 PM   #2
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
Re: Gas pedal is loose
Make sure the 2 bolts are holding the thottle linkage securely to the firewall, if bolts are tight, the brass bushing are probably wore.
Also check the little bolt on the end of the shaft where the arm is under the hood, make sure it is fully seat on the shaft, it'll give it some play. Mine did this.
For a replacement I believe this is a wrecking yard only part. You might be able to take the housing (that mounts to the firewall) minus the arm & shaft to the hardware store, and try to match it up.
If you do go to the wrecking yard, make sure you get the throttle off the specific truck that has the same type of engine inline 6 truck, or a V8 truck. The arm is bent a little different.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
