Old 08-24-2006, 03:21 PM   #1
amloya
Printed Circuit Board
I just replaced the printed circuit board on my 70 Custom 10. Half the dash lights were not working, but all gauges worked fine. Now that I have replaced the circuit board, all of the dash lights work fine, but the brake light (on bottom left side of fuel gauge) works some times and others not. Also, the tachometer works OK if headlights are off but when I turn headlights on, the tach revs up to 4500 rpm and works backwards. When I accelerate, it goes down to 3000 rpm as if it was wired up backwards. This only happens when the headlights are turned on. Any ideas what might be the problem?
amloya is offline   Reply With Quote
Old 08-24-2006, 06:31 PM   #2
qksilver
Re: Printed Circuit Board
sounds like ground problems
qksilver is offline   Reply With Quote
Old 08-24-2006, 06:48 PM   #3
amloya
Thanks. Any idea what I need to check? I don't remember disconnecting any grounds when I pulled the dash out to replace the circuit board.
Old 08-24-2006, 10:18 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Did you post the same thing somewhere else? I coulda sworn I responded to this already.
I would start by adding a bround from the dash, to the 'tin' in the back of the inst panel. Just a section of wire with eyelets on the ends will do.
Old 08-26-2006, 11:10 PM   #5
amloya
Thanks. I think there were two posts out there, but one must have been erased. What do you mean by tin? Do I need to connect the ground wire from the dash to one of the screws holding the circuit board to the gauges?
Old 08-27-2006, 12:33 AM   #6
byrd
Union Electrician
byrd's Avatar
No you need to connect the ground wire to one of the 8 mounting screws that holds the tin and the plastic bezel together.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 08-27-2006, 02:47 PM   #7
Longhorn Man
as long as it is bolted to the metal backing, it won't matter where. Personally, I like putting it where the printed circuit board bolts on and grounds to the tin.
