Gear Vendors Overdrive install
I have searched the forum, and didn't come across anything, was thinking maybe I missed it, is there a write-up on a gear vendors OD install, in particular I am interested in what the process entails to go onto the back of an NP205 t-case. I have seen a couple of pictures, is it just an adaptor, no cross member? Does the adaptor pitch the unit toward the rear end, or is it level with the transmission/t-case centerline?
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's ![]() 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
The LuvShack Garage
Re: Gear Vendors Overdrive install
Not sure about a write-up, but we do have a member w/ one in his rig
![]() As for who it is and what his user id is all I can say is someone please ![]()
I was wondering the same thing............I've been debating about putting one on my K-20 as well............I was also thinking about a Ranger OD from Advanced Adapters, but that would require a tranny/t-case move 6" or so to the rear of the truck, which would require driveshaft work(No biggie) but I don't think the SM465 shifter would clear the bench seat, and the t-case shifter would be iffy.
I would just like more splits for the gears I currently. I seen a Dana splitter on ebay acouple years ago for $400 which is what the Ranger is patterned after............I am STILL kicking myself for not clicking the "Buy it now" button.........I imagine most people wouldn't want them since it is another stick to run, but having been raised around old Macks with Du and Tri-plex's it doesn't bother me ![]()
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
ttt...........I'd like to hear more about one of these behind a NP205.
![]() Join Date: Mar 2003
You remove the rear yoke and seal housing, they give you a clamp that holds the rear bearing in place. Then the adaptor bolts on. The unit follows the centerline of the shaft. The wiring harness (hooked up correctly) will not allow O.D. engagement in 4wd. Just make sure that you shim the small sleeve correctly. All the instructions are in the package. Not all that hard.
#6 | |
I have the unit on my K 10 shortbed and I've had no problems with it. I went to a TH400 and had to move everything back about 4 inches. Just get the rear drive shaft shortened. No Problem. Of course my truck has no lift on it. You can see some pics of it on my link.
#8 | |
[IMG] ![]() Last edited by rage'nrat638; 08-30-2006 at 07:20 AM. |
I've got one on my CST 2wd behind a TH350. I don't know if your questions are 4wd specific but I'd be glad to answer any questions if I can. I LOVE my GV unit!! It works great. I installed it myself and the instructions in the kit were great.
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
#10 | |
I was wondering what the benefit of the GV verses a 700R4 or a 200R4? It seem like a lot of money for an overdrive. JRB |
#11 | |
That is more of the reason I want such a unit, need the extra gears for towing.
#12 | |
JRB |
I don't think the splits would much...........The OD in the truck original high gear does. The splits ease the shock loading on the drivetrain while towing IMO, and like I said, sure makes it easier running in the mountains and hills with the extra speeds.
#14 | |
No way you're gonna trash an TH400/OD in the same time as a 200/700. I've been thru enuff hassles w/ T700's that there's NO WAY I'll go that route again. Maybe 4L80 ![]() Splinting is cool cuz you can keep it in the powerband all the time if you're willing to click and shift. Last edited by Schralper; 09-01-2006 at 12:28 AM. |
#15 |
http://www.gearvendors.com/
The only issue w/ a 4x4 is driveshaft angle. I'm planning on installing a GV OD behind the T400 in my 2wd p/u. |
#16 |
you get a lot quicker acceleration with the extra gears
68 short step, 406/700r4, 9" w/discs. |
#17 |
How much does one of these units go for?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
#18 |
Hey JRB. Its a lot of money but with a th400 and the GV unit I feel like the strength is there to tow with confidence. Also I had a 700R4 in my Vette and really didn't like the 1st gear. Can't use it in 4wd though. RPM's on the highway came down about 1,000 at 70mph. You get to use your cheaper transmission and still have OD.
#19 |
![]() Join Date: Feb 2004
I ran a GV OD in my 86 toyota 4wd behind a 350 turbo and a NP205 --- newer transfer cases may have a switch that does not allow the overdrive if in 4wd ---- if you do not just hope you can lose traction on either ther front or rear if engaged while in 4wd. I traded my np205 GV adapter for one without the transfer case --about $600 for my 2wd 67 C10. I like the gear vendor but unless you run a lot of HP or heavy towing --- a 700R4 is less expensive. GV's are better than $2600 now plus you have the cost of a trans.
#20 | |
#21 |
2600 bucks into a 700r4 should make it bulletproof. i'm sure you can get a pretty stout one for around 2k (i think)
#22 | |
I would want one for the fact that I'd rather pay a bit more for a GV for behind a SM465, than put a NV4500 in for ALMOST the same amount of money and only gain 1 gear(OD)...........And if I sell the truck, take the GV off, put the stock parts back on and the GV goes to the new toy with a proper adapter.
#23 | |
![]() Yeah the truck weighs 3 tons but so what. I still waould rather have a TH400/GV OD |
#24 |
I am on my 3rd 700 in my '90 burb also with a 185k on the speedo. Another 1,500 for the trans or about 3,000 for the conversion of the 400/gear vendor unit. I have a GV unit in my 69 GMC, but this time I personally couldn't justify the expense. I wish they hadn't jacked their prices so much. So I fully agree.
#25 | |
This thread is the first I've ever heard of this concept. Gotta love this board! I just spent about an hour reading their website. WOW!!!!!!!!!! I thought I was going to have to risk a 700r4, and I have NO luck what-so-ever. Now I know, I will just save my money until I can get the GV unit for my th350. It is a brilliant concept, and good to 1200hp in some apps.! I do have a question or two for you guys running them. The website says it's an easy system to operate, it it seems so. Is it really? Are you any more busy in the cab than you were before? If so how, and how much more? After the intitial GV unit, what were your actual added expenses installing it? Are there any quirks one might want to know about? Upshifting? Downshifting? Hesitation? Jerks? Bangs? Pops? Anything? I notice fluid changes are recommended every 5,000 miles or so. How difficult is this to do? What fluid does it use? Anyone using/seen other manufacturers units? Is so, how do they compare in your opinions? Thanks for the info, and enlightenment (once again), Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
