08-26-2006, 10:21 PM | #1 |
Tips on breaking in new disc brakes??
Just as the title says.... Any tips appreciated!
Thanks!
78 C10 LWB Super Cheyenne |
08-26-2006, 10:39 PM | #2 |
Re: Tips on breaking in new disc brakes??
Always put that "anti-squeek" stuff on the back of the pads before installing. You can also take some emory cloth to scuff up the disc prior to installing....
08-26-2006, 11:03 PM | #3 |
Fabricate till you "puke"
Go out and do 6 or 8 medium/hard stops from say 45 mph, allowing time to cool......then just drive her like you would. L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
08-26-2006, 11:08 PM | #4 |
Check out this article:
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
08-26-2006, 11:22 PM | #5 |
sufficiently talented fool
Everything that I have read recently recommends that you brake normally and avoid panic stops or excessive heating of new rotors/pads for 500 miles. The new materials used work better and last longer with a break in period. The older non-metallic pads did better with a few hard stops to seat the pads.
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
