08-10-2002, 09:11 PM | #1 |
What can I fill this hole in the firewall with?
I am not using an e brake on my truck, but I never even gave it a thought about filling the hole for the cable, before I painted this thing......Is there anybody that makes a square/rectangle type rubber grommet or something I can put in the hole? Thanks
69 C-10 Pro Street...........red on black...........big block and a lot of go fast stuff under the hood Still in progress ........... |
08-10-2002, 09:34 PM | #2 |
Try three thicknesses of rubber (truck inner tube??) One inside, one in center the size of the hole, one outside---glue together with yellow gorilla snot (3M weatherstrip glue) Trim for neatness.
Stepsides look like real trucks! Smitty |
08-11-2002, 12:08 AM | #3 |
Haven't got and idea what to use to fill the hole. But in missouri when you get an inspection they check yer e-brake for funtion. Unless "you know someone" who inspects.
08-11-2002, 01:54 AM | #4 |
Recovering Truck Driver
you might try getting a new original style grommet for the hole, then filling the hole for the cable with # 2 permatex black and smoothing it for purtyness.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
08-11-2002, 03:04 AM | #5 | |
Bloo
no inspections in kentucky stano not in my part anyways, not sure about where brad lives
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
08-11-2002, 06:13 AM | #6 |
I will go with O'l Buck get a new original style grommet for the hole then in the gromment all you will have left is a smaller round hole I would try putting one of the black plugs that hold your fire wall insulation pad on in the smaller round hole.
08-11-2002, 06:20 AM | #7 |
1969 Custom 30 wrecker
I wouldn't run without one myself. I always make sure mine are in good working order too. They call it an emergency brake for a reason. If you lose your regular brakes, you can use the emergency brake to stop. (carefully) I used this to get home one day after a big rock destroyed my brake lines.
What about parking on a steep hill? It's not something most of us do daily but you never know when you'll have to. Very bad for the transmission or worse for the front end of you truck when it lets go and rolls down the hill!
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
