Old 08-29-2006, 12:09 AM   #1
Ron 586
RIP Mr Ron
Ron 586's Avatar
Can this be done.
I have an old 1967 C-30 truck that needs everything. It is complete but wore out. I have 3 mid seventies 1 tons with good front ends under them. Can I do like the C-10 guys and swap a late model front cross member with a power steering box under it. Has anyone done it and what kind of trouble did you have. I know it would be a lot easier to just build the later models but I just can't take this old girl apart. Any help is appreciated. Thanks.
Ron (Mr Round Tuit)
Be kinder than necessary, for everyone you meet is fighting some kind of battle
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Ron 586 is offline   Reply With Quote
Old 08-29-2006, 08:53 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: Can this be done.
It should be pretty much a bolt in, but you will have to "oblong" a couple bolt holes. The crossmembers are said to be the same , from 10-30 series. Just be sure to use ALL the steering linkage from the later truck. best of luck, L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-29-2006, 09:54 AM   #3
Tony@AirRideTech
Junior Member
I have not done this swap on the one tons but.... the one tons and 3/4 tons actually share most of the suspension components in the front end. That would leave be to believe that it will be the same to swap as a 1/2 ton.
Tony@AirRideTech is offline   Reply With Quote
Old 08-29-2006, 04:15 PM   #4
Ron 586
RIP Mr Ron
Ron 586's Avatar
Thanks guys. I haven't messed with any 1 tons or 4wd stuff in a long time. Let the destruction begin.
Ron (Mr Round Tuit)
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Old 08-30-2006, 06:57 PM   #5
Bob Moore
Ron - If your frame is a 67 1T you will probably have to dimple it to fit a PS box. Heat and a BFH will do the job. I have yet to see a 67 frame (1/2, 3/4 or 1) that had a dimple to fit the PS box.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 08-31-2006, 08:58 PM   #6
Ron 586
RIP Mr Ron
Ron 586's Avatar
Thanks Bob, now that I'm ready to try to save it I have 2 people trying to buy it. Strange.
Ron (Mr Round Tuit)
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
