Old 08-29-2006, 06:14 PM   #1
chevyboy55
chevyboy55's Avatar
Plug wires & ram horns
I want to route the spark plug wires between the block & ram horn exhaust.
Wondering what people have done to prevent wires from burning on exhaust?
I have thought about making a shield & putting a adhesive backed heat barrier on it.
http://www.jegs.com/webapp/wcs/store...tegoryId=20801
chevyboy55 is offline   Reply With Quote
Old 08-29-2006, 08:34 PM   #2
kwmech
Re: Plug wires & ram horns
What do you mean between the block? Do you want to go around or over the top?
Old 08-29-2006, 08:41 PM   #3
chevyboy55
chevyboy55's Avatar
I want to go from the dist. around the back of the valve covers with the wires tucked up against the block. Basically I want the wires pretty much hidden.
Old 08-29-2006, 08:43 PM   #4
kwmech
Stuff is readily available, the trucks came from the factory with the wires tucked around and behind the manifolds. Are you running an HEI
Old 08-29-2006, 09:25 PM   #5
chevyboy55
chevyboy55's Avatar
Yes I'm running an HEI
Old 08-29-2006, 08:43 PM   #6
qksilver
vette engines ran them under the ram horns with sheilds and brackets
qksilver is offline   Reply With Quote
Old 08-29-2006, 10:07 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Just route them around and under. Use small seperators to tie them together....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-29-2006, 10:26 PM   #8
Boog
laying low
Boog's Avatar
Hi ken. It seems to me the early small blocks had some metal brackets that bolted to the block behind the manifolds that were actually the wire holders. Probably near impossible to find these days? And what brand of wires are those anyway? I like the boot on those. I would like to know just what application to ask for when I go to buy my wires. I have HEI and headers now but will go to the ram horns later.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-29-2006, 10:28 PM   #9
Primered_69
Primered_69's Avatar
Check out
http://67-72chevytrucks.com/vboard/s...d.php?t=193938
has all the info you are looking for
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 08-29-2006, 10:30 PM   #10
Primered_69
and here
http://67-72chevytrucks.com/vboard/s...d.php?t=179725
Old 08-30-2006, 09:20 AM   #11
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Mine go behind the manifold and between the block and the engine mount. That keeps the wires away from the manifold without any special bracket.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 08-30-2006, 12:23 PM   #12
BubbaGreen
Go for 1975 Corvette wires, they should work with HEI
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
