Old 08-30-2006, 11:53 AM   #1
Zonaman
Zonaman's Avatar
Question Stock vehicle height?
I was flipping through the '69 sevice manual and couldn't find it. I searched the threads with no luck. Does anyone know just exactly what is stock vehicle height for '69 C-10 LWB? Where's it measure from?
Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 08-30-2006, 12:24 PM   #2
jimmydean
jimmydean's Avatar
Re: Stock vehicle height?
I can measure mine when I get home from the top of the wheel arch to the ground. My tires are close to stock size, so it should give you an idea. My springs might have some sag though.
My truck is stock in my avatar.
jimmydean is offline   Reply With Quote
Old 08-30-2006, 01:16 PM   #3
68Stepbed
68Stepbed's Avatar
http://www.earlyclassic.com/tech.asp...nce%20Photos-2
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-30-2006, 02:49 PM   #4
Zonaman
Zonaman's Avatar
Originally Posted by 68Stepbed View Post
OK I see it but where's the numbers for stock height. I see wheel & tire size but no actual measurement. Did I miss it?
Thanks.
Old 08-30-2006, 10:38 PM   #5
70heavyhalf
Factory Truck Stance for a 1/2 ton shortbed is 32" in the front from the top of the ark to the ground and 34" in the rear
i think but i may be wrong.
_______________
70 1/2 ton
70heavyhalf is offline   Reply With Quote
Old 08-31-2006, 06:52 AM   #6
Blazer1970
Blazer1970's Avatar
There is no standard. Different springs were available, as well as different options (engines, trannies, etc.) that make the front and rear weights (and therefore heights) of the trucks vary.
Blazer1970 is offline   Reply With Quote
Old 08-31-2006, 08:19 AM   #7
68Stepbed
68Stepbed's Avatar
No there are no measuremenrts on theEarly Classic site. LMC has some figures that are the same as 70heavyhalf posted. I believe those heights are standard 1/2 ton numbers.
Matt
Old 08-31-2006, 05:11 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
69 1/2 inches acording to GM. That is for a base model CS series truck. (That would be a 250/3 speed for engine/tranny combo.)
*edit* that is from the parking lot to the roof top.
