08-30-2006, 08:39 PM | #1 |
need help fitting bigblock 4x4
need help has anyone put a big block in a 67-72 4x4 trying to build 68 sub 4x4 502/400/205 what engine cross member do i use
08-30-2006, 09:20 PM | #2 |
Re: need help fitting bigblock 4x4
They made some stands for the 454 that was in my '72 K-20..........Wasn't a bad job, but they cut out the one to clear the exhaust manifold, which should have been plated with a half piece of tubing to strengthen it. But it fit and worked well otherwise. I can take pictures of them since I not longer use them. Would probably even unload them if your interested.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
08-31-2006, 01:16 AM | #3 |
Re: bigblock 4x4
Joe - GM did not build a BB 4X4 until 73 plus. Try to find a 73 + cross member.
Use search to contact LIVERAT - the early (67-72) BB 4X4 guru. He can set you straight. Good luck and have fun - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
09-01-2006, 12:13 AM | #4 |
Re: bigblock 4x4
My Suburban had a 350, someone took it out and put a '79 GMC 454 in it and made a crossmember from scratch out of 1/4" steel plate and reinforced the heck out of it. I wish I had a camera so I could get some pics of it. They did use the factory holes in the frame for the original crossmember though.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
09-05-2006, 11:10 AM | #5 |
Re: bigblock 4x4
I used the original crossmember but if I did it over I would use the 73-up crossmember. Using it and a bit of a body lift often times allows the engine to fit with minor firewall modifications.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
09-05-2006, 04:43 PM | #6 | |
Re: bigblock 4x4
They didn't hack up the firewall at all when they put that one in the truck I have..........It was tight, but wasn't touching the dist.
