09-02-2006, 10:04 PM | #1 |
Air bagged truck getting an wheel alignment?
I was just wondering what you all do so you don't wear through tires left and right. I didn't think that any place will check your alignment if you truck is airbagged. Am i wrong? I am planning on bagging my truck and would like to make the tires last as long as possible. Thanks Josh
09-02-2006, 11:23 PM | #2 |
Re: Air bagged truck getting an wheel alignment?
set your bags to desired ride level and have the shop align from there. make a note of the pressures and use this when driving.
09-02-2006, 11:57 PM | #3 |
So wheels shops will align them. They just wont honor a warrenty? Thanks.
09-03-2006, 09:34 AM | #4 |
i am unaware of any sort of "warranty" on any alignment job, regardless of whether a vehicle is bagged or not.
If you have concerns about warranty's and increased tire wear, then baggin' may not be for you. |
09-03-2006, 09:36 AM | #5 |
Sold! 2 days after finished
When I took mine to get alligned I had 4 pcs of 2x6 box tubing that I put under the frame, aired it out and had the allignment done there.
09-03-2006, 11:24 AM | #6 |
Happy to be here
NTB used to offer an unlimited mileage warranty, but they don't any more. Like Shane said, find out what your optimum ride height is. Try it at different air pressure until you find one that allows you to drive without adjustment. Once you determine that air pressure take your truck and have it aligned there.
Problem solved...
09-03-2006, 01:17 PM | #7 |
You absaloutly can get an alignment done, it might be a good idea to go check out the shop and see what kind of rack/machine they have.
I aligned mine at work, we have the new Hunter DSP600 with a sunken hoist http://www.hunter.com/pub/product/al...946T/index.htm the sunken hoist is A HUGE FACTOR, not too many places have it, you'll have to bring some 2x6's or somehting along so you can drive up the ramps, like i said ours is completely sunken in so all i have to clear are the jacks in the middle of the hoist. This is how mine aligned at 75 psi and 25 psi, i will cruise it lower, but if i'm gonna roll on the highway or something these are the pressures i'll use to keep the tire wear down. Now the huge factor with mine is that i went from 3" dropped coils to 3" dropped spindles and springs, my truck was aligned with just the coils and everything was within spec, then once i put in my airbags and dropped spindles, all i had to do to align it was set the toe, the dropped spindles don't change your alignment too much. There are maybe 3 shims on each stud of the control arm, i don't know where this BS about 3" of shims came from its simply not true. Having said that i'm in the process of plumbing the onboard air and getting shorty headers and the exhaust tucked in, i'll align it again when its lower and post the results. Any questions let me know. I used 63-66 4x2 pickup specs, i'm sure anything up to 92 will get you the same specs. As for warantees on alignments...its generally going to be none at all, waaaaaay too many factors.
1964 - LWB 350 TPI Fuel Injection On airbags Last edited by jasonrmorrow; 09-03-2006 at 01:24 PM. |
09-05-2006, 08:28 PM | #8 |
What about the Warranty on New Tires? Can we still get the new tires warrantied with bags?
'67 C10 Short Stepside 5.0TPI/700R4 |
09-05-2006, 08:55 PM | #9 | |
Like someone else said, if your worried about warantees on your customized vehicle then it isnt for you. Drive it at the aligned height 90% of the time and your tires wont die too early, and even if they do...its your fault, not the tire. And you'd have to be Waaaaay out of alignment to wear tires at a considerable rate, so get it aligned, drive it at that height and dump it for pulling into the cruise night or whatever.
1964 - LWB 350 TPI Fuel Injection On airbags |
