09-03-2006, 02:42 PM | #1 |
6 lug rotor suppliers?
hey guys,
i am currently swaping my 69 front drums for 71 disks and i was hoping someone may know where i can get 6lug rotors. i know ECE supplys them but does anyone else? ondrew |
09-03-2006, 03:13 PM | #2 |
Re: 6lug rotor suppliers?
McGaughy's has them. The kit is $239. It includes everything but the spindles.
09-03-2006, 03:14 PM | #3 |
www.mcgaughys.com 559-226-8196
09-03-2006, 03:22 PM | #4 |
i allready have everything else. all i need is rotors.
09-03-2006, 03:41 PM | #5 |
I would give them a buzz. Maybe they will sell them seperate.
09-03-2006, 03:45 PM | #6 |
They are basically 5 lug late model (73-87) rotors that they redrill to a 6 lug pattern. Many different after market suppliers. I remember a while back that someone used like 95 heavy duty half ton rotors to do a swap. Not sure if they will go on the spindles you have unless you sue different inner wheel bearings. I think it was dennis brooks who did it.
I would check with one of the board vendors I know they carry them. |
09-03-2006, 05:48 PM | #7 |
Re: 6 lug rotor suppliers?
GMC Pauls sells 6-lug rotors that are a direct swap to the 5-lug disc spindles. Theirs are not re-drilled though. From what I understand, they get them as 'blank' rotors & have them drilled w/the correct 6-lug pattern from the start.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-03-2006 at 05:48 PM. |
09-04-2006, 12:28 AM | #8 |
I also have them available as well.
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
09-04-2006, 08:35 AM | #9 |
pickupman.....how much are they???
09-04-2006, 09:38 AM | #10 |
Just the rotors run $175 for the pair
09-18-2006, 07:19 PM | #11 |
72 BB C30 Super LongHorn
This might not apply to this thread but I will try...
How about 6-lug truck rear disc rotors ... I have seen newer trucks from GM using rear disc brakes. What is available in this application? Thanx!
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS |
