Old 09-03-2006, 10:32 PM   #1
timcos
Chief Honcho In Charge
timcos's Avatar
Windshield Washer Pump and Reservoir
Hi all,
When I get my truck back from my mechanic this week (went there first to get running, inspected and lubed as I just got it) I am going to replace the washer pump with an electrical unit and also wire it so the pump pumps when the wiper switch is depressed (I found a good wiring thread on this here on the board). The pump will be underhood.
OK...so what is the good pump motor to put in? Just one of those generic ones from Checkers/AutoZone/Pepboys?
And has anyone found a great solution to a reservoir? I like where the stock one is but it is awful small..would love a one gallon reservoir.
Cheers,
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 09-04-2006, 11:28 AM   #2
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Re: Windshield Washer Pump and Reservoir
I used http://www.jcwhitney.com/autoparts/P...tt=washer+pump from JC Whitney for $11.99. Hooked it up to the stock wiring so it works when the button is depressed like you want to do. Mounting location wise, just make sure it is close to the reservoir and at or below the fluid level because these electric pumps are weak and won't function otherwise. The stream is acceptably strong; I'm satsified.
badpeanut is offline   Reply With Quote
Old 09-04-2006, 01:09 PM   #3
rage'nrat638
rage'nrat638's Avatar
heres another jc sells i like this one
http://www.jcwhitney.com/webapp/wcs/...OnB%0AKDAZmtNM
rage'nrat638 is offline   Reply With Quote
Old 09-04-2006, 12:28 PM   #4
dallas71
dallas71's Avatar
or even this one with the tank included....
http://www.jcwhitney.com/autoparts/P...DSHIELD+WASHER
dallas71 is offline   Reply With Quote
Old 09-04-2006, 11:43 PM   #5
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Get one of these from a Mitusbishi or Dodge import. Knock the mount off with a chisel or screwdriver. Works great.
low'n slow is offline   Reply With Quote
Old 11-04-2006, 10:51 AM   #6
timcos
timcos's Avatar
OK...got the goods.
Which wire do I run to the underhood to power my washer pump, so that when I depress the switch it squirts?
I looked at the wiring diagrams and it looks like the LBL or DBL...not sure which. I know I read this somewhere but my search (wrong word combo mostly) did not prodiuce what I read.
Looks like the 18Y wire is the power feed from the fuse box.
Or is not that easyt to simply extend a wire forward?
Thanks in advance.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 11-04-2006, 05:42 PM   #7
timcos
timcos's Avatar
Alright...if it weren't so wierd it would be funny.
I have used my wipers a few times in the last few months...and the pump never worked.
I get in the beast this morning...and I turn on the wipers and the pump is going all by itself and won't stop. I dpress the switch a few times, switch it form lo to high...turn it off...turn it on again....squirting would not stop. I stop at the grovery store...some back out of the store...get in and it was not pumping...and no amount of depressing the switch would get it to pump again.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 11-04-2006, 06:11 PM   #8
Boise69
The Hammer Man
Boise69's Avatar
Yea what the hell just throw a Yugo unit in there it dont matter just as long as it holds water and squirts right?! #%#^&
Boise69 is offline   Reply With Quote
Old 11-11-2006, 12:05 AM   #9
timcos
timcos's Avatar
OK...got the goods.
Thanks in advance.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 11-11-2006, 12:55 AM   #10
low'n slow
low'n slow's Avatar
If I recall there is a blue and a yellow wire. I pulled the connector off the pump and used a spade connector on the new wires.
Old 11-11-2006, 01:03 AM   #11
timcos
timcos's Avatar
What do I do with the yellow or blue wire?
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 11-22-2006, 07:44 PM   #12
low'n slow
low'n slow's Avatar
Tim,
The yellow and blue wire get connected to the washer pump. You will have to extend the wires. I used a vacuum tee on the fluid line. PM me if you need some more pictures.
As far as using a Yugo pump, who cares. It works better than the stock unit.
Old 11-26-2006, 11:04 PM   #13
timcos
timcos's Avatar
All done...works like a dream.
http://67-72chevytrucks.com/vboard/s...d.php?t=217477
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
