Old 09-07-2006, 02:23 PM   #1
1969K10
1969K10's Avatar
axle ID help wanted
Sorry I've been gone, but I'm between jobs until Monday, and don't have access to a compter w/o going to the library...
I've recently picked up a set of K20 axles from a late 70's chevy. The rear is a 14-bolt with the removable pinion. The #'s on the axle are:
3877323
the "8" might not be an 8, "9" is my next guess.
Can anyone tell me what year and anything else?
Thanks!
1969K10 is offline   Reply With Quote
Old 09-07-2006, 04:28 PM   #2
70rs/ss
70rs/ss's Avatar
Re: axle ID help wanted
Sounds to me like an eaton, a pict would be good. Removable pinion, from the front like a ford 9", if so then eaton, not a 14 bolt (14 bolt has a rear cover like most rear ends for access to the gears)
70rs/ss is offline   Reply With Quote
Old 09-07-2006, 05:47 PM   #3
Blazer1970
Blazer1970's Avatar
Removable pinion is a full floating 14 bolt. You are thinking about a drop out third member (Timken style axle). If the front is a Dana 44 and not a 10 bolt, it is '78 or older. If it is a 44, the easiest way to ID the axles is by the BOM number that is stamped on the tube of the front axle. The number is stamped on the tube facing forward just to the right of the pumpkin. It will take some scraping to see it if the axle is rusty. You are looking for a 6 digit number that starts with a 6.
Blazer1970 is offline   Reply With Quote
Old 09-08-2006, 12:38 AM   #4
1969K10
1969K10's Avatar
I'm fairly certain the front is a D44. Looks just like the D44 I got in (6-lug), but I haven't scraped the numbers.
