Old 09-08-2006, 12:24 PM   #1
Luvlegs
Luvlegs's Avatar
coil spring mounting - clarification?
Last night I saw in one of the aftermarket repair manuals, an actual photo of the upper mount "retainers" for the coilspring -
Their pic showed the cup facing up so the smaller center stuck down into the spring - if the rear was ever lifted high enough, the top of the spring would not be held by anything.
I know I took mine off and put them back the same way - cup facing down - right? ('72 C-10 2wd)
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 09-08-2006, 12:39 PM   #2
raggedjim
raggedjim's Avatar
Re: coil spring mounting - clarification?
Every truck i've had (about 10 of them...) all had the spring trapped between the frame and the large outer lip of the cup so the bolt mounting hole area sits flat against the frame. You should not be able to jack up the frame and have the spring disengage fron the cup.
I think the manual is wrong...
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 09-08-2006, 01:01 PM   #3
Luvlegs
Luvlegs's Avatar
That's what I thought. The only thing I could think of, is that the manual is for 67-80 something - perhaps a newer model has a bit different setup. It was hard to distinguish any year from the photo. Thanks for the response.
1972 C10 L6 3OTT
Old 09-08-2006, 01:05 PM   #4
daveo68
daveo68's Avatar
Raggedjim is right,the manual is wrong.
68 C-10 Custom LWB
307 V8
Lexington,NC
davideowens@lexcominc.net
God Bless America
daveo68 is offline   Reply With Quote
