Old 09-09-2006, 07:40 PM   #1
71/454
Turbo Guy
71/454's Avatar
Frame differences c-20 vs c-10
Like it says, are the frames the same height. Could a guy make a c20 a c10 by just bolting on c-10 upper and lower control arms and spindles and cross link. And by changing the rear diff?
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
Old 09-09-2006, 08:59 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Frame differences c-20 vs c-10
the frames are 99% the same, jut some added braces.
The whole front suspention needs swapped, and the rear axle too.
Old 09-10-2006, 03:34 AM   #3
71/454
Turbo Guy
71/454's Avatar
Can you swap just the a frames or do you have to swap the crossmember too. I only ask because i have the a frames on the floor but no crossmember. What about the steering box?
12 bolt diff
Old 09-10-2006, 06:29 AM   #4
Longhorn Man
frames... i assume you mean a arms? I couldn't tell you.
the steering gear box is the same C/10 -C/30.
Old 09-10-2006, 10:22 AM   #5
68jimmy
68jimmy's Avatar
That is basically what I did with my 68 GMC... I started out as a 2500 with a 351 V-6 and 3-speed column shift. Now a 350/TH350 sits there with crossmembers I salvaged. I converted the heavy leafs and rear diff to a trailing arm setup with a 12 bolt 3.07. The front was almost the same, except that I left the lower c-20 arm installed a c-10 upper and used the spindles/disc brake setup from a 90 chevy.
It can be done just take a grinder and a few grade 8 bolts...
Here is a pic of mine now that I've got it rolling again.
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 09-10-2006, 12:23 PM   #6
classicchev
classicchev's Avatar
Dave, I have a bare 3/4 ton frame and a bare 1/2 ton frame and if you put them side by side the only differences are:
of course 5 bolt front spindles and diff
rear springs are bigger
rear crossmember has a couple diagonal braces to the frame rails
a couple other braces here and there
A arm U bolts a larger
Other than that they are pretty much identical. Im sure everything will just bolt on. I even think withe the correct ball joint the spindles will interchange(i should have tried this before I put the 3/4 ton stuff back on)
Darren
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 09-10-2006, 10:53 PM   #7
71/454
Turbo Guy
71/454's Avatar
Thanks for your help guys, man i love this site!
12 bolt diff
Old 09-11-2006, 12:54 AM   #8
ClemsonChevy
8 vehicles only 4 that run
ClemsonChevy's Avatar
Well heres my question then: Why are the cab mounts different between C10s and C20/30's? Can you interchange them? Is the difference just that the 20/30's are stiffer supporting?
95 2500 350 w/ 3.73
72 GMC 1500 SWB stepside
65 Chevy C10 SWB stepside
72 Chevy C10 LWB fleetside
ClemsonChevy is offline   Reply With Quote
Old 09-11-2006, 09:52 PM   #9
Longhorn Man
WOAH!!! good point!
The cab mounting pads on a 2 wheel drive 1/2 ton is higher. (needing shorter rubbers) All the other trucks require the tall rubber mounts due to a lower mounting pad.
Old 09-12-2006, 09:58 PM   #10
ClemsonChevy
I also just noticed that the rad core supports are different rubbers also. Is that just like the cab, to add more "cushion for the pushin'".......for the rougher duty trucks?
95 2500 350 w/ 3.73
Old 09-15-2006, 02:00 AM   #11
71/454
Turbo Guy
71/454's Avatar
looking at the cab mounts that was my first impression. I'm guessing that the stiffer springs make the truck ride rougher so they put in fatter cab mounts to soften it up. The cab mount being lower in the rear was the only thing i can find different so far
12 bolt diff
