Old 09-11-2006, 02:56 PM   #1
vfx3dartist
vfx3dartist's Avatar
vacuum/carb/newb question
Hey All - I decided to swap the old air filter and original setup for a basic edelbrock chrome air cleaner, but I’m not 100% on the vacuum hookup. Does the vacuum advance line go to the open spot on the carb? I tried this and it seems to run fine, but was fast at idle. Do I need to dial it back after the swap? Pic below.
-j
vfx3dartist is offline   Reply With Quote
Old 09-11-2006, 03:05 PM   #2
woodridge
woodridge's Avatar
Re: vacuum/carb/newb question
Dizzy needs to hook to a port that does not have vacume at idle but when the throttle start to open. There has been much discussion on this but with this setup you can run the most initial advance and have the best idle.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 09-11-2006, 07:30 PM   #3
qksilver
yep, the advance needs what they call ported vacuum, so a source above the throttle plate needs to be used
qksilver is offline   Reply With Quote
Old 09-11-2006, 09:00 PM   #4
GREASEMONKEY72
GREASEMONKEY72's Avatar
i hope this helps but i pointed out my vacum line from the dist to the front of the carb and mine works fine so i hope it helps and the tube on the side of mine is capped off
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
