Old 09-11-2006, 04:05 PM   #1
alpar80
bed rails
What is the best way to remove and mount side rails to an existing bed?
alpar80 is offline   Reply With Quote
Old 09-11-2006, 10:45 PM   #2
roj2323
Re: bed rails
i'm assuming our refering to the aluminum caps they make for protecting the top edge of your bed sides.
i've seen eveything from doubble sided tape to large eye bolts. it really depends on what you're going for. looks or functionality. if it's looks then some quality doubble sided tape/foam might do the trick but if your going for function then large eye bolts in the stake pockets might be the direction you want to go.
ondrew
roj2323 is offline   Reply With Quote
Old 09-12-2006, 07:39 AM   #3
Re: bed rails
I`m assuming you mean the rails that mount on top of the bedsides,as offered through the dealer accessory book.They mount by drilling holes at the mounting locations and running a sheetmetal screw into the body.You could drill through,then use flat or ovalhead machine screws,washers,and lock-nuts.
Old 09-12-2006, 11:32 AM   #4
alpar80
Re: bed rails
Actually they are the side rails that hold the wood of the bed to the body. These are the stainless steel rails that mount on the bed sides and run at 90 degree angles to the oak, they seem to be possibly tack welded into place however, I dont know. I am redoing the bed and need to remove the existing ones to replace them with new stainless.
Old 09-12-2006, 11:36 AM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
Re: bed rails
They are spot welded to the bed. If you can't see the spot welds, you can stick a large screwdriver or something similar under the rail and push it away from the bed, you should be able to tell where it's spot welded after that. You can drill or grind them out.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-12-2006, 04:09 PM   #6
alpar80
Re: bed rails
Ill give it a try thanks.
Old 09-13-2006, 01:10 PM   #7
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
Re: bed rails
This may help. http://www.mar-k.com/54-72anglestrips.pdf Let us know what you find. Originally the angle strips were steel, spot welded to the bedside about every 3 inches. Stainless angles are not original. There are any number of ways they could be attached.
Mar-Ktech
GET MAR-K Quality!
Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks
MAR-Ktech is offline   Reply With Quote
Old 09-13-2006, 02:21 PM   #8
alpar80
Re: bed rails
Thanks for the info Mar-K. BTW I jsut ordered the bed restoration info manual with a catalog, so Im sure Ill be ordering some parts soon.
