Old 09-12-2006, 07:27 PM   #1
florida4x4
Bushwacker Cut out Flares
Bushwacker lists part numbers 40015-11 and 40016-11 for the C/K series but not a Blazer / Jimmy. The fenders look close enough but does anyone have pics or experience installing flares on a K5?
1972 GMC Jimmy - 383SBC | TH350-NP203-NP205 | D60PL | 14FF Detroit | 42 TSL's | 4Xeyes | Heavy FOotE
"Trail in. Trash out."
Florida4x4 dot Com
florida4x4 is offline   Reply With Quote
Old 09-12-2006, 08:00 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Bushwacker Cut out Flares
Do you have a set of the flares? They stopped making them for the first 67-72's many years ago. If you have some for a pickup, they will fit the Blazer. The fenders and wheel openings are the same. Make sure they aren't for a '73 + though.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-12-2006, 08:19 PM   #3
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Cutting your fenders? http://darthno.ytmnd.com/
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 09-12-2006, 10:36 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Maybe on a trail rig, but I have to agree w/ 2wdBlazer
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-12-2006, 10:37 PM   #5
florida4x4
OK, cool. I hate tall trucks and the 39.5's are just too big for the 6" lift. I've moved the front axle forward a couple inches but still need some room. The back axle could be moved but relocating the spring perches is a little too much work for what I'll gain. the cutouts should give me what I need. Now if I can find a set...
Florida4x4 dot Com
Old 09-13-2006, 06:48 AM   #6
vtblazer
vtblazer's Avatar
Welcome to the board.
What lift are you running?
What kind of wheeling are you doing? Mud/rocks...everything?
To run 39.5's you either need to lift...ALOT or do the cut thing, no in between.
All depends on your useage and how you feel about chopping up old iron.
I had the same issue and went with the cut option.
vtblazer is offline   Reply With Quote
Old 09-12-2006, 08:48 PM   #7
makovai
makovai's Avatar
You can still get the truck cut-away's. Coincedently i just called on these today because as you can see i have a wheel covering issue. But according to 4 wheel parts they were never available for the blazer.
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
Old 09-12-2006, 11:51 PM   #8
IGOR
IGOR's Avatar
Flat conveyor belting riveted around the wheel well - yeah that's the ticket!
-Ben
1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer
1972 K10 - Rust Bucket, TBD
1976 C10 SWB, 350 / T350
My blazer build thread:
https://ck5.com/forums/builds/72-k5-...17-update.410/
IGOR is offline   Reply With Quote
Old 09-13-2006, 08:06 AM   #9
Go ahead and cut.There`s more sheetmetal where that came from.I`m a fan of minimal lift,too.I hope cut-outs and a6" lift will be enough.You may need 8".When I see the cut-outs for 67-72s,they don`t appear to open up the wells that much over stock.
Old 09-13-2006, 10:15 AM   #10
florida4x4
There was a Blazer in the top truck challenge years back (maybe 2002) that had the bushwacker flares running 44's. I thought the article said he used 73- up flares but I could be wrong. It looked like it opened em up pretty good. Wish I could find a pic or the old magazine... well anyway I'm running a set of Skyjacker 6" springs and thinking if cutting doesn't do it then i'll put on a 2" body lift. Being in North Florida I wheel mostly trails and mud but I will try anything.
I wanted to maintain the original lines to the point that I considered sectioning out the wheel wells and adding a couple inches in the middle. Not too bad on the front but the back is a *****. I put a lot of panels in this truck and frankly I'm burned out on hammering sheet metal.
Florida4x4 dot Com
Old 09-14-2006, 06:41 AM   #11
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
from Michigan and good luck with your situation. I would throw my opinion in there too, but I like tall trucks.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 09-14-2006, 07:54 AM   #12
TTC:
Old 09-14-2006, 08:06 AM   #13
florida4x4
heheheh, now THAT Jimmy is Ghetto! It's not the one I remember though. It was a primer grey Blazer that a dude drove from the east coast - cross country. He competed, won or nearly won and then drove it back home. If that story has any truth to it the dude was nuts!! It was looking good IIRC...
Florida4x4 dot Com
Old 09-14-2006, 09:10 AM   #14
Yeah,that Jimmy`s a bit over the top.
I used to live between Stuart and Ft.Pierce along the Indian River(Walton).I did some of my favorite wheelin`there in The Savannas.Can you say "blackwater"?No rocks,just bottomless goo anywhere off the beaten trail.We all had the huge tires back then.
Old 09-14-2006, 12:05 PM   #15
florida4x4
That sounds like good wheeling there. We have a lot of sandy roads, some minor off camber stuff and a lot of black mud when it rains enough.
Say are those flares Bushwackers? They look generic and, well, too damn big..
Florida4x4 dot Com
Old 09-15-2006, 08:54 AM   #16
florida4x4
Well I found a write up that I think has the Blazer I was talking about. 1997 TTC. Damn time flys http://www.4x4now.com/trcatt.htm
There is a video of it going through the mud pit. Those bushwackers are just too nasty for my tastes. Guess I'm cranking up the sheet metal saw, mig, and pastic surgery paste...
Florida4x4 dot Com
Old 09-15-2006, 10:37 PM   #17
2wdBlazer
The Blazer King
2wdBlazer's Avatar
They don't look too bad but I like my fenders. Kind lookes like MAC's truck
http://www.4x4now.com/trcatt2.mov
Old 09-15-2006, 10:53 PM   #18
onetonk5
Cereal Killer
onetonk5's Avatar
hey i bought my first cross over steering from that guy........wow that was a long time ago.....that was a bad ass k5
onetonk5 is offline   Reply With Quote
Old 09-16-2006, 06:25 AM   #19
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
No-way man, that thing is freak'n cool
Old 09-15-2006, 11:31 PM   #20
Yeah,they`re pretty fang dugly.
Old 09-16-2006, 02:31 AM   #21
earl87gta
earl87gta's Avatar
didnt he open a shop in Havlock NC theat blazer is at the off road shop thier and the owner of the shop said that it is his truck and he drove it in TTC I wish I could remember the name of the shop and the guy now. but is any one is in the area you can go check out the blazer.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 09-16-2006, 07:52 AM   #22
Uh,I meant over the top as a good thingI should be a politician,I agree with both of you
Old 09-16-2006, 08:35 AM   #23
makovai
makovai's Avatar
I looked thru all my pictures. (im weird, i have a pic of every 69-72 blazer i can find) Anyway this is one of the better looking flared trucks.
www.fast77.com
1996 Z71 w/ 35's
Old 10-06-2006, 09:13 AM   #24
florida4x4
Thanks for that pic. cant decide if they work against the lines or not. tough decision...
Florida4x4 dot Com
Old 10-06-2006, 09:45 AM   #25
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I think that looks better than the traditional saw-zaw hacking corners off the fenders.
side note: Why not try to modify some Ford flares? All the newer trucks have round fender wells.
