09-14-2006, 12:23 PM | #1 |
Determining 1973 Blazer axle ratio?
Assuming a stock ratio, is there an easy way to determine the stock ratio (i.e. build sheet, stamping on the axle, etc.)
Thanks! |
09-14-2006, 04:09 PM | #2 |
Slots go on anything!
Re: Determining 1973 Blazer axle ratio?
It should give you the ratio on the option lable, which is either in the glove box or the inner fender (if it's still there). I would guess 3.73, but I may be way off.
09-19-2006, 06:28 AM | #3 |
There is also a stamping on the axle tube. I helped my friend find it on his 77 K5 because the sticker was missing in his glove box. It was located on the driver side axle tube, but I can't remember exactly where. If I remember right it was a 3 letter code. Be prepared to scrape off dirt and stuff too. Then call the parts department (I think it was the parts department, my friend made the call) at the dealership and they should be able to tell you what that code means.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
