Blazer tank install
How hard is it? My bed doesnt have any wood in it, so would i have to remove it? Can anyone give me some tips or tricks? also, can i use the tank and sender from a 73-87 blazer?
TTT
Can anyone help me? i am thinking about doing it on thursday so i would like to get some info. thanks
Seņor Member
If your bed has no floor, this should be ultra-easy to install. That's how I did mine... from the top and it took a couple of hours. The messiest part was cutting over from the other tank, since I had to yank the old fuel line. After I got a nice bit of gas down my arm and into my hair I decided to run the new fuel line all the way to the front anyway.
Don't forget to run a wire back with your fuel hose. You'll need it to connect your gauge. Good luck. This is a pretty easy conversion. Kenneth
here is mine.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club Last edited by Jwill41; 08-13-2002 at 09:02 AM. |
L.E.D. Tail lights, Baby!
I was going to ask about that. Gracias.
Prov 3:5-8 "Hook 'em" L.E.D. Taillights for sale NOW!!! If interested, visit: www.earlyclassic.com or our website: www.jmcled.com All 67-72 GM Taillights are on sale untill 5 p.m. on Dec 15th, with Guaranteed Christmas delivery! joel.mcwaters@jmcled.com |
ttt
1971 Chevy SWB Oklahoma City, Oklahoma |
chevypunk
The hardest part is trying to decide how you want to run your filler hose. It looks like jwill41's comes out in the wheel-well. BTW, nice job jwill41! I chose to place mine on the wall, inside the bed. Some of these old trucks came with a filler guard mounted inside for a spare tank. I snagged one from a junk yard. It protects my filler hose and has the metal snout that holds my filler cap. Came out nice. Easy access also. Someone on the board posted pics of one done in a tail light or side marker light. I have that link still (I think) if your interested. The rest is simple. Run a wire # 12-16 for gauge, filler hose, return line for filler, supply to carb, and a return if needed. Good Luck! |
I had to add strips on each side to prevent mine from slipping through the frame.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
another pic
