Old 09-16-2006, 09:47 PM   #1
rancid
rancid's Avatar
69 or 72 crew
well heres my collection of good parts that now makes up a 72 3/4 ton and my 69 cab. so now i got to decide if i want my crewcab as a 69 or a 72. but atleast i have most of the parts to start this project. cant wait to start chopping.
this when all though a long bed now should end up with a 5ft-2in bed when cabs are joined and suburban door parts and roof parts are added.
rancid is offline   Reply With Quote
Old 09-16-2006, 09:55 PM   #2
Re: 69 or 72 crew
You sound like me.I have all this stuff and so many ways to go.When you build from scratch,you just pick a year from what parts you have(and what titles you have for the registered year).I can`t wait to see some cutting,either.
Old 09-20-2006, 09:03 PM   #3
rancid
rancid's Avatar
Re: 69 or 72 crew
well got my 2nd cab a 69 here and cut the front out and cut the back out of the 72 cab and got it on the frame . and streched the wheelbase 23 inches so far may adjust it once the cab is done and i start fitting the bed. it just looked goofy with the tires almost against the cab. heres some pics of where im at, going to get suburban front doors still and sqaure up the rear doors. and get some sheet metal bent up for the pillars between the doors and roof bent up to close up the cab next. and im also going to do a little more trimming to get both the doors closer together.
Old 09-20-2006, 09:14 PM   #4
CPNEJR
CPNEJR's Avatar
Re: 69 or 72 crew
that thing looks like it's gonna be awesome!
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 09-24-2006, 02:49 PM   #5
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Re: 69 or 72 crew
That's a great project! gonna look bad when is done, keep us updated!
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 09-24-2006, 10:27 PM   #6
rancid
rancid's Avatar
Re: 69 or 72 crew
well i was going to use a suburban door post and roof area to complete the connection between both cabs, but there will be a lager gap between the doors , so i will have to modify it anyway. so i decided to cut an area where the roof, rain gutter and the jamb area, as a sample. so i could have a 56 inch long prebent pieces done and join the roof and gutter area. then once thats done i will have the vertical jamb area bent for it. so i will have the pieces on tuesday.
Old 09-24-2006, 10:49 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: 69 or 72 crew
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-07-2006, 07:49 PM   #8
rancid
rancid's Avatar
Re: 69 or 72 crew
well i got my bent up peices of metal back 3 different bends where done and i got 2 of each and to fab up the jamb area and i will fab up the vertical one next.monday i got 2 71 buckets and a center console for 75 bucks even though there in grey tweed , and scored up all three suburban doors and an auto tilt column for 100 bucks last night, im only using the rear door for the sqaured post area on the truck rear doors. so still need another suburban rear door wing window. but i think it will work out pretty good.
Old 10-07-2006, 07:51 PM   #9
rancid
rancid's Avatar
Re: 69 or 72 crew
try again.
Old 10-07-2006, 08:03 PM   #10
timcos
Chief Honcho In Charge
timcos's Avatar
Re: 69 or 72 crew
Where are you in Utah?
Cheers,
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 10-07-2006, 08:29 PM   #11
rancid
rancid's Avatar
Re: 69 or 72 crew
im in riverton.
Old 10-07-2006, 08:31 PM   #12
rancid
rancid's Avatar
Re: 69 or 72 crew
well i hope this goes well, first time doing anything like this. i guess we all need to learn.
Old 10-07-2006, 08:49 PM   #13
rancid
rancid's Avatar
Re: 69 or 72 crew
Old 10-07-2006, 09:03 PM   #14
rancid
rancid's Avatar
Re: 69 or 72 crew
having pic problems.
Old 10-07-2006, 08:38 PM   #15
Re: 69 or 72 crew
Truck looks like it is going to turn out real nice. I like the way you ar going at things with it.
I tried and fixed a few of your photobucket links. Got most of them to work for you.
Old 10-07-2006, 08:39 PM   #16
timcos
timcos's Avatar
Re: 69 or 72 crew
If you need help...I am only about 20 minutes away. I can lend a steady hand and an inquisitive mind.
Cheers,
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 10-07-2006, 10:19 PM   #17
rancid
rancid's Avatar
Re: 69 or 72 crew
Cheers,
cool, i may need a hand im still learng alot of this. i normally do solid axle conversion and work allot on newer trucks. and im finding sheet metal is not as forgiving as box tube and 1/4 inch plate. and i have alot of metal to replace and add in on the giant floor of this thing.
Old 10-08-2006, 01:03 AM   #18
chevy_fatman
Where's my beer?
Re: 69 or 72 crew
Looking good!! keep up the good work man!
Paul
Old 10-08-2006, 11:15 AM   #19
Hart_Rod
Hart_Rod's Avatar
Re: 69 or 72 crew
Nice project. Here are some pics of mine:
Hart_Rod is offline   Reply With Quote
Old 10-08-2006, 12:15 PM   #20
rancid
rancid's Avatar
Re: 69 or 72 crew
could you get more pics of all the middle door jamb areas inside and out. and what parts where used to build that 4 door, modified suburban rear doors or truck doors.
Old 10-08-2006, 01:14 PM   #21
Hart_Rod
Hart_Rod's Avatar
Re: 69 or 72 crew
Mine has 4 full size truck doors. Rokcrwln built one using the suburban rear doors for the back doors.
http://67-72chevytrucks.com/vboard/s...d.php?t=188993
These are the best pics I have until I pick the truck up. Try this link also:
http://67-72chevytrucks.com/vboard/s...53#post1757553
Old 10-08-2006, 01:18 PM   #22
Hart_Rod
Hart_Rod's Avatar
Re: 69 or 72 crew
How about some inside pics? Are you making it a shortbed?
Old 10-08-2006, 02:55 PM   #23
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 69 or 72 crew
Nice work rancid!
CAL 58 GMC is offline   Reply With Quote
Old 10-08-2006, 03:37 PM   #24
Aarons72s
Re: 69 or 72 crew
I want one!
Aaron
Aarons72s is offline   Reply With Quote
Old 10-08-2006, 04:09 PM   #25
rancid
rancid's Avatar
Re: 69 or 72 crew
was a long bed, but im going to use this bed. it will be cut down i think about 20 or more inches from the front of the bed and pretty much bob the back of the bed. i did move the spring hangers about 17 inches back.
and thanks for the pics, just trying to get an idea how to finish the vertical jamb.
