Old 09-17-2006, 09:32 AM   #1
62 short step
62 short step's Avatar
power booster
Has anyone put one from an 80's chevy truck on a 60-66 chevy truck. I have one so thats why I ask. Jeremy
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 09-17-2006, 09:41 AM   #2
Dadsredwagon
Dadsredwagon's Avatar
Re: power booster
sorry , off topic , but really like the color of you truck... what color is it? any details you can share?
thx
Dadsredwagon is offline   Reply With Quote
Old 09-17-2006, 01:13 PM   #3
62 short step
Re: power booster
I really don't know. It was painted 2 owners ago, and the one I bought it from did'nt know either. If I ever repaint it I'll go with the same if I can figure the color out.
1965 c-10
86 chevy c/k 20
Old 09-17-2006, 06:54 PM   #4
62ChevyStep
62ChevyStep's Avatar
Re: power booster
We did to my mine (62' Stepside). along with the whole front crossmember, spindle to spindle, power steering, etc.
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 09-17-2006, 08:35 PM   #5
62 short step
Re: power booster
What year power brake booster did you use?
1965 c-10
86 chevy c/k 20
Old 09-17-2006, 10:56 PM   #6
62ChevyStep
Re: power booster
1986, booster, proportioning valve, master cylinder, etc. I have used alot of parts off the 86'.
i will shoot some pics tommorrow and post them here for you of the engine compartment so you can see.
Old 09-18-2006, 12:11 AM   #7
Hilandr451
Hilandr451's Avatar
Re: power booster
You'll need to fabricate the mounting bracket and you might need to use part of the old push rod, but other than that, it should work fine. I bought the whole setup already engineered for my '66 from Chevy Duty $375.00 - came with everything including a zinc plated mounting bracket.
Greg Smith a.k.a. "The Highlander"
1966 C20 Custom Camper, 2017 Chevy Silverado 1500
Highlander's Project Pics
Highlander's web site: www.6066ChevyTrucks.com
Hilandr451 is offline   Reply With Quote
Old 09-18-2006, 08:33 AM   #8
62 short step
Re: power booster
I looked at the ones from Chevy Duty and was going to buy one, then I came across a 83 4x4 that I'm going to use the newer front axle and the 700r4 in my 61. So I have that booster already thats why I was asking. I can deal with a little fab up. Thanks Hilandr451. Jeremy
1965 c-10
86 chevy c/k 20
Old 09-24-2006, 11:59 AM   #9
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
Re: power booster
then I came across a 83 4x4 that I'm going to use the newer front axle and the 700r4 in my 61. [/QUOTE]
Did you do a conversion to 4x4 or was it that way ? if converted how hard was it to do?
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
Old 09-18-2006, 08:28 AM   #10
62 short step
Re: power booster
Sounds good thanks!!
1965 c-10
86 chevy c/k 20
Old 09-18-2006, 03:53 PM   #11
64Leo
New Member
Re: power booster
I didn't have the bracket for my booster either, but I just mounted it directly to the firewall on my '64. The firewall was flat, so i figured it would be alright. Just had to add some threaded rod and a clevis to the cab side to attach to pedal. works like a charm.
64Leo is offline   Reply With Quote
Old 09-18-2006, 06:48 PM   #12
62ChevyStep
Re: power booster
here are some current pic's
Old 09-18-2006, 08:54 PM   #13
62 short step
Re: power booster
I'll will probably try what you did. Maybe I will not have to fab up a mount, if I'm lucky! Thanks
1965 c-10
86 chevy c/k 20
Old 09-18-2006, 08:51 PM   #14
62 short step
Re: power booster
Thanks 62 chevy step, wow real close to my handle(62 short step). Can't wait till I start on mine. The power brakes will help alot on the 61 4x4!! Thanks again for the pics.
1965 c-10
86 chevy c/k 20
Old 09-23-2006, 10:26 PM   #15
zenish
Re: power booster
i just put a 1973 booster on my 64 c10 yesterday.the booster bolted right to the old master cylinder holes.the push rod was too short but the rod end unscrewed so i used a barrel nut and a piece of allthread to extend it.i had to drill the hole at the pedal from 1/2 to 9/16.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 09-24-2006, 11:24 AM   #16
62 short step
Re: power booster
Thanks Zenish, I'll let yall know how it went when I get it done.
1965 c-10
86 chevy c/k 20
Old 09-24-2006, 06:34 PM   #17
62 short step
Re: power booster
It is a factory 4x4. Just going to put an open knuckle axle with disc brakes, power steering,etc.
1965 c-10
86 chevy c/k 20
