Old 09-17-2006, 09:48 PM   #1
mtb_will_03
mtb_will_03's Avatar
Line Lock
I just finished putting in my malloy ignition and the next thing im thinking of doing is buying line lock.
Was wondering if their is any pointers or things I should know befor I do this.
mtb_will_03 is offline   Reply With Quote
Old 09-17-2006, 10:05 PM   #2
qksilver
Re: Line Lock
I wouldn't advise using it instead of an emergency brake. Over the years almost 30 years on and off in the towing business, I have learned not to trust them for longer periods other than loading, winching or recovering, and even then if it isn't level to block/chock the wheels.
Had a few unlock on me in the early years.
For drag racing, have no idea, I always had the rear brakes adjusted loose
qksilver is offline   Reply With Quote
Old 09-17-2006, 10:11 PM   #3
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: Line Lock
Make sure you have a good tubing bender. Line locks are only meant to be used for less than 30 seconds. At least that is what the instructions say. I use one on my 66 Chevelle. At the track they say only to use them for the burnout, and that's all I use it for.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 09-17-2006, 10:19 PM   #4
bigjimzlll
bigjimzlll's Avatar
Re: Line Lock
The mounting location of the mallory box could be better...they do not like water...at all
On the line-loc...just follow the instructions.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 09-17-2006, 10:58 PM   #5
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: Line Lock
Ive had a line lock for years in my truck. I use it for burnouts and man it works slick. Tubing bender is a must I wish i had one years ago. Pump the pedal a couple of times and hold it down... push the line lock button and tramp the throttle. Let go when you burn enough rubber
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 09-18-2006, 09:42 AM   #6
junkyardjohn
junkyardjohn's Avatar
Re: Line Lock
I've Had Them On A Couple Of Trucks & They Are Great. I've Had Them On Fwd Trucks (try Backing Down A Steep Wet Clay Hill During The Rain With A 4 Speed). They Work Great If You Buy A Good One. Cheap Ones Are Well... Cheap. I've Used Em For Years Without Any Problems. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 09-18-2006, 11:00 AM   #7
mtb_will_03
Re: Line Lock
Where else would you recommend puting the box ?
Old 09-18-2006, 03:58 PM   #8
el curioso
el curioso's Avatar
Re: Line Lock
I dont know about line locks but those glass fuel filers are some thing that you should really be carefull about. Some people round here have some intresting stories about them bursting. jmo
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 09-18-2006, 07:11 PM   #9
bigjimzlll
bigjimzlll's Avatar
Re: Line Lock
I originally like mounting them on the fire wall....now they go inside..behind the glove box.
Anderson,CA
Old 09-18-2006, 07:41 PM   #10
LONGHAIR
Re: Line Lock
Second on that ^^^^^
LONGHAIR is offline   Reply With Quote
Old 09-19-2006, 08:02 PM   #11
Rdrdave
Broke and still trying
Rdrdave's Avatar
Re: Line Lock
Run no filter rather than THAT filter. Nice and explosive! I used a linelock on my "stang" and it worked great for burnouts at the light. People wondered why your brake lights aren't on and you are just pouring on the smoke!
Rdrdave is offline   Reply With Quote
