09-18-2006, 11:30 AM | #1 |
Battery cutoff switch and cd player memory
Im going to put one of those battery cutoff switches under the dash for safety and security reasons.
I know Ive seen something before that prevents the memory on my cd player from being wiped out evertime the power is cutoff. Anyone know what Im talking about?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
09-18-2006, 11:36 AM | #2 |
Out of the carpool lane.
Re: Battery cutoff switch and cd player memory
I've heard of using a 9V battery hooked up to an old cig lighter plug-in from a cd player, but I never got that to work for me. I think there's another way by running a wire directly from the battery to the cd player or something like that. Other people should chime in shortly with info on how to make this work.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
09-18-2006, 12:59 PM | #3 |
It's a catastrophic success.
Just use a small wire 16-18 ga. to loop around the cutoff, It will supply the memory power but will burn into if you try to start the truck.
09-18-2006, 02:15 PM | #4 | |
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille Last edited by pat; 09-18-2006 at 02:17 PM. |
09-18-2006, 02:21 PM | #5 |
YES, A fuse would allow you to replace it if you ever forgot to switch the master.
09-18-2006, 01:22 PM | #6 | |
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
09-18-2006, 03:28 PM | #7 |
I've been wanting to put a cut-off switch on my truck as well. Does anyone have any idea as to how much a cut-off switch cost and where to get one?
09-18-2006, 03:37 PM | #8 |
its all about the +6 inches
Something that could be done that would possably be better, or at least nicer...
Put a forrd type Starter relay inline between the battery(s) and the starter, wire the trigger wire to a push button under the dash. Pres the button as you turn the key, and it starts like normal. If you don't press the button, it'll just click, like if you had a dead battery. You could get real slick and mount the button on a fabbed plate on the brake pedal. Hold the brake down as you crank it, or just clicks if you don't hit the brake. I've seen this done where the cigarette lighter completed the circuit, but I don't recall how the heating element was bypassed to complete a circuit. However, by going this route, the whole vehicle is still wired up, you can liten to the radio, the dome light will still work... 4 ways.. etc. You are ONLY inturupting the main cable to the starter, the rest if the truck is untouched. |
09-18-2006, 07:29 PM | #9 |
Is this a newer style radio with a yellow memory wire?
If so, why not just run a separate wire, say 18ga, to the battery to power the memory circuit on the radio? Then you won't have to carry a box of fuses around with you to replace the blown one when you forget flip the cutoff switch. Just be sure to fuse the 18ga wire within 12 to 18 inches of the battery. Should not need a large fuse, 5 amp will do. In your pic all the power to the truck would go through the small wire if you forgot to flip the switch. If you use a 20 amp fuse with an 18ga wire you may heat the wire up pretty hot if you turned on an accessory that needs less than 20 amps with out flipping the cut off switch. The 20 amp fuse would allow all that current to go through the 18ga wire possibly melting it. 18ga wire is only recommended for up to about 16 amps for chassis wiring. Mike
1968 Chev SWB Fleet with GMC Clip and lots of 71-72 parts! Last edited by JustLiveIt; 09-18-2006 at 07:30 PM. |
09-18-2006, 08:29 PM | #10 | |
If anyone would like the entire .pdf which is full of various uses for automotive relays (neat ideas for starter kills, simple alarms, etc.) send me a PM with your e-mail address and I'll send it out. Be forewarned though it is almost 3MB!
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
09-19-2006, 12:12 AM | #11 |
Msgt USAF Ret
If you are doing this to prevent a thief from stealing your truck then you're wasting your time. I could defeat any of these ideas and have your truck running in less than 30 seconds and so could any thief. VV
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
09-19-2006, 12:42 AM | #12 |
You need to break the actuall posative or negative battery cable to slow the theifs down.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
09-19-2006, 01:25 AM | #13 |
Im mainly going for this on the advice of the shop that helped build my truck. He said he almost had one of his rods burn up b/c of an electrical problem and suggested I do this just to be safe. I plan on getting a good alarm, which I know probably wont stop a professional thief either, but what can you do.
09-19-2006, 11:56 AM | #14 | |
Cantankerous Geezer
There are two styles of mechanical switches. One replaces the positive battery cable clamp, and has a green knob to turn, cost is under $10. The other is a large, rotary switch that mounts in a panel. This is a far better switch, but also costs much more. I haven't bought one in years, so I don't know the price. Both should be available at your local mom & pop parts store.
Fred There is no such thing as too much cam...just not enough engine. |
09-19-2006, 01:25 PM | #15 | |
Also, when running the wire before the switch I can use it to power an alarm as well as the radio memory right?
09-19-2006, 03:16 PM | #16 | |
You can use the "hot all the time" wire to power an alarm too that you put under your dash. Just make sure you use the appropriate wire gage and fuse rating to handle the alarm's current needs as well. A five amp fuse and 18 gage wire is plenty if you just want to power the radio's memory. Increase that if you hook up the alarm too. Mike Edit: smbrouss70 you beat me to it!
1968 Chev SWB Fleet with GMC Clip and lots of 71-72 parts! Last edited by JustLiveIt; 09-19-2006 at 03:17 PM. Reason: added comment |
09-19-2006, 12:44 AM | #17 |
I know you can't "stop" them, just trying to slow them down a little. If they really want it, they'll get it.
09-19-2006, 03:12 PM | #18 |
yes, there are 2 power wires to "newer" radios. One for just the memory, and another that is switchable with your ignition.
Yes, you can use the same wire to run your alarm also. The memory lead on your radio draws VERY little amperage so you shouldn't have any problems.
09-19-2006, 03:18 PM | #19 |
Sorry!
Yours was more in depth, though.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 09-19-2006 at 03:19 PM. |
09-19-2006, 04:40 PM | #20 |
Awesome! I think thats everything I needed to know. Once I find some time to get it done Ill let u guys know how it went.
Thanks a lot
09-19-2006, 05:53 PM | #21 |
Here is a question... or rather a comment...
A properly fused electrical system CAN'T be the fault of a fire, so if you do up your harnesses right, and have the right guage wire, then there is pretty much no risk. |
09-19-2006, 06:48 PM | #22 |
True, but I dont trust myself and after I smelled my neutral switch melting Ive been nervous about it ever since.
