09-19-2006, 11:02 PM | #1 |
its all about the +6 inches
anyone able to rebuild quadra-jet carbs?
Anyone able and willing? I have one off a 78 or maybe 79 caddy 425, I want it rebuilt before I mount it to an intake, and last time I opened one of these suckers up, it never went back together.
How much would you want? |
09-20-2006, 12:13 AM | #2 |
Re: anyone able to rebuild quadra-jet carbs?
Hey Longhorn Man,
I would be glad to it for you if you were closer as I have done hundreds of them over the years. I would do it free of charge (as I am retired-or is that retarded?) but by the time you paid shipping here and back plus the kit and a float and filter, you could probably have a pro close by do it and come out cheaper. Done so many I could take one apart with my eyes closed.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
09-20-2006, 01:53 AM | #3 |
Jhow, where could I get a kit or? to put bushings in for the throttle shafts
09-20-2006, 07:13 AM | #4 |
Junior Member
I used a guy in Milford, MI zip 48381. He is retired from Rochester. He charges $150.00. I can get his phone number if you want. Mine looks really nice but I have not tried to start the engine yet so I do not know how well it works. Paul
09-20-2006, 11:23 AM | #5 |
qksilver you can buy kits at any parts store. Just take the carb # with you. The # is to the right of gas feed lever-it will look like this --704'''''''' or 1704'''''. I have not replaced any shafts as they seem to work fine without doing it. Shaft wear is cause mostly by using too heavy of a return spring (such as a valve spring ). Dive in you can do it.
09-20-2006, 11:32 AM | #6 |
Anyone wanting to know what thier carb came off of can check here:
http://www.teufert.net/
09-20-2006, 07:25 AM | #7 |
Andy, I'm about the same as jhow66 I could do it but shipping would probably be more expensive than local repair(in fact i've got a caddy 795CFM on the bench right now).
qksilver: http://quadrajetcarburetors.com/index.html
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI Last edited by neonlarry; 09-20-2006 at 07:26 AM. |
09-20-2006, 10:05 AM | #8 |
I ran across this guy on eBay, he is in Arkansas - 30 miles south of Ft. Smith.
THE COST TO REBUILD YOUR 70 BIG BLOCK TRUCK WOULD BE $168.00 PLUS SHIPPING. THANK YOU FOR CONSIDERING MOUNTAIN MAN FUEL SYSTEMS. 479-639-2022 TED tlowe@centurytel.net
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
09-20-2006, 10:23 AM | #9 |
I would offer to do them too... i dont find them that bad, and ive prolly memorized most of the pages in doug roes book ... but anyway, if time wasnt a huge factor (I started my doctoral work at Univ of Minn) i could do them too... only thing is if i needed replacement parts would have to order them as my parts stash is in storage right now... i would say in the 100-150 range and ill always be willing to trade for stuff and just put the word out that i can do a good job!!! PM me if anyone is interested....
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
09-20-2006, 11:48 AM | #10 |
I had mine rebuilt from Jones Fuel out in California. They did a great job. What really cost was shipping there and back but all in all it was around $215. You tell them your motor, modifications vehicle and so forth. I was very happy.
09-20-2006, 03:17 PM | #11 |
shipping would only be 5 bucks or so each way... DHL is DIRT cheap.
I'll look into some locals first, may refer back to you guys though. Any locals have a good carb guy? |
09-20-2006, 05:08 PM | #12 |
Msgt USAF Ret
Here is a good website for rebuilding the Q-Jet. They din't get into replacing the throttle plate shaft bushings however. To me this is a must do on an older carb because if they are worn they will not hold a steady idle.
C'mon Andy give it a try. http://www.4wheelnoffroad.com/qjet.html
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
09-20-2006, 05:34 PM | #13 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
09-20-2006, 07:18 PM | #14 |
Not to hi jack your thread but thanks guys for the info on the bushings....Doug Roe book?
09-20-2006, 07:40 PM | #15 |
yes the bible as far as quad's go... mine is about wore out, but my quad confidence went way up after reading and reading and ... well you get the picture... Do a search on amazon for "Doug Roe" and/or "quadrajet" and itll come up... heres the link
http://www.amazon.com/Rochester-Carb...e=UTF8&s=books Give it a try and its only 12 bucks... so 12 bucks + good read + $25 rebuild kit + vac gauge + timing light + tune time = HE** of a lot of fun!!! and good milage and pretty good reliability.... i like them better than holley or edelbrock for sure... any questions at all lemme know.... --Mike
09-20-2006, 11:06 PM | #16 |
Jeg's has some nice ones if you can afford it.http://www.jegs.com/webapp/wcs/store...tegoryId=10271
If your set on rebuilding yours I would find someone local with a good reputation. BTW I have a Qjet off my 79 1ton that came with a 454. I don't know anything about it, but if it's a better one to rebuild than what you have you can have it.I cant really afford to be a member quite yet but want to contribute to someone who contributes to this awsome forum.
1970 custom/10 (was 8-350) long bed factory a/c,power steering, power brakes added front disc brakes from a 72 and rear axles 5 lug 79 chev 1 ton 01 GMC Jimmy |
09-21-2006, 06:53 AM | #17 |
I just sent a diesel injector pump to MI for a rebuild for $12.Seems worth it.I`m sure there`s a good local rebuilder for your Q-Jet.The last one I had done cost $75,just bolt on and go.Prolly gone up a bit,huh?The I/P I`m sending back to the modifier to get back to specs(whatever they are),it`s like secret ingredients in mom`s potato salad.
09-21-2006, 09:17 AM | #18 |
Chief Honcho In Charge
I took mine to a place in Salt Lake City called Carburetor Exchange. 189 for a q-jet rebuild.
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
09-21-2006, 04:57 PM | #19 |
yeah, the local rebuilders, whom i question, quoted me a "good guy price" of 225.
I think when I get back from San Francisco next week, i might just take one of you up on the offer. |
09-21-2006, 06:32 PM | #20 |
I have had pretty good luck with BFIC Fuel Systems in Calif. I know they have rebuild kits for just about anything. They are at www.carbsonly.com
They also do rebuilds, but then again shipping may be an issue.
Original owner '69 C20, long, fleet. 454 BB with Edelbrock stuff. Work truck for years, 2nd restoration going on. '69 C20 '03 Tahoe Z71 70 Hp Johnson pushing aluminum bass boat. All things in life are uncertain, so eat dessert first. |
09-21-2006, 07:14 PM | #21 |
Cost me about $15 to ship a carb from PA to FL. I need a Holley rebuilt so I may try here...good luck
______________________________________________________ My Garage: 1968 SWB K-10 2005 Tahoe UH-60A/L Helicopter FLY ARMY! |
09-21-2006, 11:10 PM | #22 |
I`ll check K&K Automotive`s latest price in Frederick,MD.Unless the price has changed an awefull lot,it`s nowhere as expensive as what these guys are saying.The do a great job,been using them for 30+ years.They domy startersand alternators,too.They`re my 'benchwork" shop.
09-22-2006, 10:21 AM | #23 |
Andy,
I would be able to do it, if you want to ship to PA. The tuning process once you put it back on the engine would require some of your time though. Setting the air door spring for the secondaries for instance. Not too hard really. I'm rebuilding the one off my '76 caddy 500 right now. Also if you guys are looking for affordable bushing kits....Summit sells them: part number JET-201102, price is $67. There are enough bushings included to do 8 carbs.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
09-22-2006, 07:00 PM | #24 |
JHOW, I just looked at that website you posted showing what cars certain numbered carbs came from. Not trying to talk bad about the site, but I think there may be some incomplete information or flat out wrong information there that may mislead people.
09-22-2006, 07:07 PM | #25 |
You might want to give an example.
