86 GMC Stepside Help
I am thinking of changing my Intake and Carb. As of now I have a stock casting intake and A Quadrajet carb (4BBL). My question. What is a good carb to use? This engine is stock and I don't want to put to much into the top end. I have been told that a Holley 650 double pumper is to much. What carbs are good from Holley and what carbs are good from Edelbrock?
As far as the intake, I was thinking edelbrock performer series. My truck is attatched. |
Re: 86 GMC Stepside Help
Performer eps 1 inch open spacer 1406 eddelbrock is my combo big improvement also if you dont mind frequent tuning Holleys are good
Insert Witty Text Here
I bought a rebuilt quadrajet from Jet performance, and installed it on a factory aluminum intake that is identical to the cast iron one that came off the truck. The intake is not rare or special, just lighter. I see them in junkyards occasionally.
I was planning to go with an edelbrock intake and carb, but the cost convinced me not to. It is especially costly if you have cruise and A/C, and want everything hooked back up like I did. All of those brackets are expensive, and substantially raise the cost of switching to the Edelbrock carb. Slonaker |
What is Performer EPS. Specificaly What does eps stand for?
i had a weiand "stealth" intake and a 600cfm Edlebrock on an old truck of mine with a stock 350 and it made a big difference from the stock setup, but it ran good too....not over fueled, and not under fueled...i've also rebuilt tons of q-jets and as long as you don't let them sit so the gas dries out or goes bad...they will last a long time...the biggest problem with any carb. is the accelerator pump...in edlebrocks and Q-jets its basically a rubber plunger. when they sit in gas and then dry out(leaving it parked for a long amount of time) they get brittle and crack so then when the accelerator pump is pushed down the gas can get through instead of being pushed into the motor....on a Holley they are more of a diaphram and those too dry out in the same way....but when the gas goes back through a dried out accel. pump on a Holley it usually leaks or sprays back out onto the intake...
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles ![]() '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L ![]() ![]() ![]() |
#8 | |
I was told by many that a rebiuld won't last or perform like a new one. If I was to rebiuld my quad, how much time can I get out of it? Or should I just buy a new one? |
#9 | |
I have also heard that the Performer is a very good carb. I chose not to get one because of the extras I would have to buy to use it. If you don't have cruise or A/C, and you want a new aluminum intake anyway, it might be your best bet. Slonaker |
Sb 400 club
i got the eldebroke 650 cfm on mine. i drive my truck in nice weather and leave it sotred for the winter months. never hadto retune it yet and it runs out really nice
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
