09-25-2006, 11:36 AM | #1 |
Axle Swap
If you put 91 suburban 10 bolt axles in a 76 blazer will the original drive shafts bolt up with out a problem ? Thanks .
09-25-2006, 06:17 PM | #2 |
Oh,you can't buy that new
Re: Axle Swap
no, at a bare minimum the rear u-joint will require the 'switch joint caue the cups on the pinion yoke are different sizes. It also requires careful measuring of the driveshaft. a 10 bolt driveshaft from blazer SHOULD be easy to find though.
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww LOTS of Cummins trucks. |
