![]() Join Date: Sep 2005
best place to get coils
like it says where is the best place to get coil srpings for the front and back of a 71 c-10 longbed. i was going to sell my truck then changed my mind and going to replace the coils and shocks and get a better ride out of the truck i am also ordering a center force dual friction clutch kit for it i tried these cheap clucths from parts stores here and they dont last long
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 09-27-2006 at 05:48 PM. |
Re: best place to get coils
What look are you going for exactly, if you are just wanting stock you should be able to get everything at your local NAPA or other auto parts store. If you are wanting it lowered check out some of the board vendors.
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons ![]() Last edited by 71SWBChevy; 09-27-2006 at 06:29 PM. |
yeah i am look for the stock ride
![]() Join Date: Mar 2001
i would replace them with moog or trw parts....
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
i've gotten springs from jcwhitney and they were very good and lots less than buying local even with paying shipping
I agree with BubbaGreen,Moog or TRW Any good parts store can get them.
Pat ![]() ______________________ 1968 1 Ton Dually Flatbed 327/th400 1968 C30 Open Road 327/th400 1997 F350 CREWCAB 4X4 460 BIGBLOCK ![]() |
napa can get hd rear springs for 107 buxs a set and 98 buxs for the hd front coils advance auto has the rancho shocks for 47 a piece think this is the way i am going to go
#8 | |
Are your current springs: Rusted and pitted Broken anywhere Noticeably fatigued Modified (by cutting or low buck dropping) Otherwise damaged If none of those apply, there is honestly no reason to replace them. Springs in general have very good fatigue life and will continue to function almost as good as fresh off the assembly line for well beyond what anyone would consider their useful life (I am talking in the hundreds of thousands of miles here). Replacing a solid spring with a new one will have absolutely no affect on your ride quality. Give them a good painting and you will never know the difference. If any of those conditions do apply, then definately replace your springs. Otherwise, replace your shocks and your ride quality will be as good as it ever was. And oh what a difference the shocks will make. |
when you start off the truck will dip to the right like i got bad springs they are rusted pretty good too
are you looking for a softer more car like ride? with the hd springs i think it will ride like a tank.
'67 c10 350/th350 |
Here is some info that I had written down, might help you out:
Front Springs, MOOG, MOG-6082, Standard Duty 1/2Ton Rear Springs, TRW, TRW-CC603, Coil springs, rear, variable rate, Hef-T-Coil, TRW. and yes, HD or heavy duty springs will ride rough
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich Last edited by BubbaGreen; 09-28-2006 at 03:04 PM. Reason: added more info |
i carry alot of weith alot of the time thats why i was going with the hd
